Samurai power steering
  • 1042 Views
« on: September 27, 2008, 11:24:11 AM »
I have an 87 Sammy w/ Jeep J10 axles, 5.13's, 33X12.50 Boggers, 1.6 8v, 6.5:1 transfer, and virtually no steering.  It is very hard to steer and the stock steering doesn't allow for full turn of the wheels.  I am headed to the junk yard this week to get some power steering parts.  My first instinct is to get sidekick parts since I have the 1.6 the bracket will bolt right on and I've been told I only need to drill 1 hole in the frame to mount the steering box.  I have however heard that this doesn't work very well.  Some have said to get a toyota pump.  So here it is: What pump, what steer box, cooler?  Please keep in mind I am broke so I am just buying junkyard parts, no expensive adapter kits.  If the sidekick stuff will work ok that is what I'd rather do.  I do have a little spare steel and a welder so I can fab a little if needed.
Offline RHodge
  • 523
Re: Samurai power steering
« Reply #1 on: September 27, 2008, 01:38:37 PM »
I used a nissan box, worked out great,  you could use the tracker pump
http://www.zukiworld.com/forum/index.php?topic=21793.0
I don't know if it was easer or not but is a option
Ryan
Offline ROSS
  • 1412
« Reply #2 on: September 27, 2008, 02:19:52 PM »
i've been using the sidekick setup on mine for 7 years . no problem
Offline idaholwb
  • 772
« Reply #3 on: September 28, 2008, 08:29:13 PM »
 The Sidekick setup will not bolt right on unless you use a kit to relocate the pump from Trailtough or Calmini.
97 Sport
265/70-16s
2" lift
2.0 swap
