Howdy, guys and gals.
2001 GV, automatic, 150k miles, pretty much stock.
Had transmission serviced Wed with total replacement pumped in. Tech said it was difficuolt to get ALL the old fluid out. Screens were very clean, and magnets had very little residue.
Before this the brakes were working fine, as power assisted brakes should. Could get the pedal to pump up at a stop, and also could get it up further with the adjusters in the rear. After the tranny service, way different brake response. More like manual than power. Will still stop the trucklet, but 2-3 inches of pedal travel b4 engaging, and take spressure and way more than usual pedal travel to come to a stop.
SO, testing shows I have good vacuum at the booster. Is the booster bad? There is no bleed by in the master cylinder. No connection to trans service that I can see, but never know.
Further, has anyone replaced a booster? Part cost and where purchased? Local numbers are just under 400 USD with minimum 4 day wait. New and remanned.
I woud appreciate anything that may be relevant. Including opinions on safety of vehicle with this problem. Wife is supposed to take this GV to the beach this weekend.
Thanks,
Pat
