New suzuki owner
  • 14 Replies
  • 2702 Views
Offline jonb8
New suzuki owner
« on: September 25, 2008, 05:47:48 PM »
Hi everyone.... My name is jon and I'm new to suzuki's. I run a offroad club in West Virginia and currently have a 89 xj on 33 boggers. My wife has a 98 xj on 33 bfg MT's. These are street legal jeeps but I went looking for a sidekick to build a all out offroader. Here is a pic of my sidekick and my jeeps. Hope to get too know you all well.
Re: New suzuki owner
« Reply #1 on: September 25, 2008, 07:45:10 PM »
Clean looking Tracker.  Welcome to the sickness.  :)
Offline Cuthulu
  • 384
« Reply #2 on: September 25, 2008, 09:38:22 PM »
Prepare to be impressed with much less.  Welcome.
Offline jonb8
« Reply #3 on: September 26, 2008, 04:12:17 AM »
Thanks, I'm already a believer. I think with a SAS this thing is gonna go anywere, and light to Tow behind my wifes xj. I'm leaning toward yj leafs and yota axles, then put my 33 boggers on it. Might coil  spring and long arm the front, still got lots of research to do that's why I'm here.
Offline OHIO_ZUKI
  • 53
« Reply #4 on: September 26, 2008, 04:23:54 PM »
 1.5"Coil lift spacers
 31" Tires
 5.12 Gears....ALL YOU NEED!
Start with the Spacers.Without the spacers, the bigger tires won't fit.
i Kant sPel.
Offline jeff1997
  • 1228
  • 27
« Reply #5 on: September 26, 2008, 06:21:45 PM »
Welcome jonb8! That blue XJ is absolutely awesome looking!!!!!!I love the older body styles when they are done up right. If you need coil or strut spacers for the Kick, I'm your man  8)
3" Masterkit1 body lift
Custom strut spacers
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #6 on: September 26, 2008, 07:04:11 PM »
Welcome to the sickness is right :P.
If you have the cash pick up this kit from trail tough. with the recommended toyota axles.
http://www.zukiworld.com/month_080106/feature_sas_sidekick_hoff.htm
"Trail Slayer" Sidekick/Tracker Straight Axle Coil Spring Conversion Kit
Turn your Sidekick / Tracker into a serious off-road machine! 40â€? of articulation and great handling characteristics!  We hate to admit it but these rigs are out-performing the even the “bad boyâ€? Samurai’s.  Because this kit takes advantage of the superior strength of Toyota axles, your Sidekick , Tracker, or X-90 becomes an extremely durable, reliable TRAIL SLAYER!!!
    Price $2795.00
http://www.trailtough.com/SAS-install.pdf
*Requires the use of 79-85 Toyota pick up front axle  and 86-95 Toyota pick up rear axle    ts
Mean Green Wheeling Machine
Offline jonb8
« Reply #7 on: September 26, 2008, 07:16:11 PM »
Thanks guy's, But I'm a kind of build it myself kind of guy. Here is a long arm coil sprung SAS we just did on my buddies 98 blazer.  This is kind of what I was thinking for the sidekick, but 4 link front and 3 link back. I don't want a street legal rig, I want low center of gravity and alot of articulation. What I have read these little boogers are the ticket and I just gotta decide which way too go. Still searching, and reading alot. Nice rigs you guy's, you build good stuff.
« Last Edit: September 26, 2008, 07:20:59 PM by jonb8 »
Offline bashzuk
  • 784
« Reply #8 on: September 26, 2008, 11:33:41 PM »
look for heather galvin's rig. They did a very nice build.
Look for fj-60 axles as they are already set up for coils :)
Offline idaholwb
  • 772
« Reply #9 on: September 28, 2008, 08:09:02 PM »
 That would be FJ-80 axles, the FJ60 was the leaf predecessor.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline bashzuk
  • 784
« Reply #10 on: September 28, 2008, 09:15:23 PM »
thanks
Offline jonb8
« Reply #11 on: September 29, 2008, 02:52:46 AM »
Has anyone used the fsj wagoneer axle, It's a 44 with a drivers drop and a 60ish WMS to WMS. Haven't found anything on this axle yet.
« Reply #12 on: September 29, 2008, 09:26:11 AM »
You see them swapped into YJ's all the time, as they are pretty much a direct swap.  The only problem with it is the drivers side drop, you need a passenger side.  You could probably get a set of axles from a Scout II though.
Offline jonb8
« Reply #13 on: September 29, 2008, 12:56:58 PM »
I'm sorry that was a typo, I meant a pass drop from a 79 and older. Sometimes my head isn't screwed on right. Thanks
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #14 on: September 29, 2008, 10:32:46 PM »
If you're going all out offroad, check out the rockstar build!
