alittle alternator help
  • 1791 Views
Offline hawaiizuki13
  • 51
« on: September 25, 2008, 12:41:00 AM »
i got a 86 samurai and i noticed the green plug on the alternator one wire is off like cut off. it also starts up and runs although the head light comes dim but with high revs its good to go what should i do buy a new plug or make the batt ground to the firewall bigger in the gauge? any help will be find thanks and aloha
LOVE TAKING A ZUK RIDE WITH MY FAMILY
Re: alittle alternator help
« Reply #1 on: September 25, 2008, 03:45:38 AM »
Get a plug and wire it correctly.
« Reply #2 on: September 25, 2008, 08:57:11 AM »
It wouldn't hurt to add an extra ground wire or two as well.  :)
Offline rascott
  • 669
  • 15
« Reply #3 on: September 25, 2008, 09:30:17 AM »
i think a little dimming of the headlights at idle is expected.
have you checked voltage at the battery?
battery voltage should be |removethispart|@ 12.5V, higher at idle(13+), and mabe 14.2V- 14.6V when turning faster.
batteries are cheap, and if your alternator is doing this then you should be good.
of course good wiring only helps.........
mabe
  • 51
« Reply #4 on: September 25, 2008, 10:35:02 AM »
thanks guys problem fix changed the plug and its gtg aloha
« Reply #5 on: September 26, 2008, 12:31:24 PM »
Maybe you owe a plate lunch to bentparts?  ;)
« Reply #6 on: September 26, 2008, 03:51:09 PM »
Beer and burger, thanks.
Offline ROSS
  • 1412
« Reply #7 on: September 26, 2008, 04:40:45 PM »
you meen BEERS
« Reply #8 on: September 27, 2008, 04:46:18 AM »
I'm not greedy, just fly me to Hawaii and I'll be happy with a six pack on the beach.
