vitara Diff Centres into Sierra
  • 1444 Views
Offline vitaradownunder
  • 62
  • Vitara Doin' it Aussie Style
    • WildZooks
« on: September 22, 2008, 07:42:06 PM »
Which is it again the Vitara front diff centre or rear diff centre into the sierra rear housing. As in theory i could run that centre in the front of the sierra with the 26 spline hardened shafts.
I did a little search and nothing really came up that was any use.
Thanks in advance.
James
Lets get wild and show the big  toys how to do it suzuki style.
Re: vitara Diff Centres into Sierra
« Reply #1 on: September 22, 2008, 09:08:02 PM »
Front diff from a 96-98 Vitara, that gives you the 26 spline side gears and it will fit in an SJ-413.  You might want to just get the gears though, and put them in a steel diff instead.  Then you can use your stock side gears.
Offline idaholwb
  • 772
« Reply #2 on: September 28, 2008, 08:27:57 PM »
 If you do just gears in your diffs you need diff cans or spacer setup from one of the Suzuki vendors. It will keep your crosspin in place where it needs to be.
97 Sport
265/70-16s
2" lift
2.0 swap
