Transmission?
  • 10 Replies
  • 1851 Views
Offline tremendous
  • 20
  • I gave him a tremendous beating!
Transmission?
« on: September 17, 2008, 07:06:53 AM »
Symptom: I'm stopped at a red light, light turns green, I accelerate, there's a bit of resistance and BOOM feels like I've been bumped from behind, only I haven't, then I'm on my way. Happens about once every other day.
What do you think guys?
'97 Suzi Sport 1.8
So polluted!
Offline idaholwb
  • 772
Re: Transmission?
« Reply #1 on: September 17, 2008, 12:11:46 PM »
 Automatic or manual?
97 Sport
265/70-16s
2" lift
2.0 swap
Offline tremendous
  • 20
Re: Transmission?
« Reply #2 on: September 17, 2008, 12:21:28 PM »
automatic
So polluted!
Offline Fordota
  • 40
Re: Transmission?
« Reply #3 on: September 17, 2008, 12:32:51 PM »
Sounds like maybe you broke a tooth off a gear and after floating around every so often it binds up. Maybe Trans or Rearend. Just an idea.
Re: Transmission?
« Reply #4 on: September 17, 2008, 12:35:51 PM »
I had a car doing that, a transmission flush fixed it.  It's probably the cheapest fix you can try.
Offline pepatt
  • 174
Re: Transmission?
« Reply #5 on: September 17, 2008, 05:16:24 PM »
Check your U-joints too. I've had one seize up on my full size pick up with the same result.
That is unless by "boom" you really mean :( BOOM! :(
Then I just don't know!  ???
pepatt
Offline idaholwb
  • 772
Re: Transmission?
« Reply #6 on: September 17, 2008, 08:41:18 PM »
 Check the gear oil in the rear diff. Specifically, look for any metallic sheen to the fluid. Or even worse, look for metal flakes or possibly chunks. Sounds like the rear diff is going south on you. Because of how the Sport ABS system is set up, you can use any Track-Kick rear 5.12 rear diff.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Armour
  • 360
Re: Transmission?
« Reply #7 on: September 17, 2008, 08:49:55 PM »
Could possibly be the trans!
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Transmission?
« Reply #8 on: September 18, 2008, 09:34:45 AM »
Might pull the rear brake drums and look around, too.
XL-7 front coils
1.5" rear coil spacers
95sidekick
Re: Transmission?
« Reply #9 on: September 20, 2008, 04:20:51 PM »
does the tranny rev up then boom an you start movin?....mine does that when the fluid is low, and cold, then i top it up an its fine....easier then fixin the leak hahaha
Offline idaholwb
  • 772
Re: Transmission?
« Reply #10 on: September 28, 2008, 08:31:10 PM »
 What have you found out so far?
97 Sport
265/70-16s
2" lift
2.0 swap
