1991 2-Door 5-speed Sidekick Ring & Pinion Gears
  • 34 Replies
  • 17447 Views
Offline Armour
  • 360
Re: 1991 2-Door 5-speed Sidekick Ring & Pinion Gears
« Reply #30 on: September 16, 2008, 04:00:06 PM »
I'm not even sure she knows whats she's doing at thia point! LOL!
Offline 83sj410
  • 46
« Reply #31 on: September 16, 2008, 06:41:37 PM »
I'm thinking someone just wants to fill a bunch of pages of babbling   ???
Who knew 45 horsepower could be so fun???
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #32 on: September 17, 2008, 07:55:19 AM »
Dude, it's like watching a fired up prosecutor going after a defendant, but in terms of zuki R&P's! LOL!
« Reply #33 on: September 17, 2008, 01:43:20 PM »
#1. "skyhiranger" &/or to whom it may concern, according to Trail Tough, the Trackick front ring gear diameter is 6.9", & the Trackick rear ring gear diameter is 7.5".  Is that correct, & would you consider Trail Tough to be a good source of information?
#2. "skyhiranger" &/or to whom it may concern, what's your reaction to the following paragraphs from Boondox Motorsports at the following URL?:
"Manual Transmission: The 5 speed manual transmission used in Suzuki's is quite capable of handling the abuse of off-road use. Unless you are going with a 200+ horsepower engine your stock transmission should be all you will ever need. The gear ratios are 1=3.78:1, 2=1.95:1, 3=1.37:1, 4=1.0:1, 5=0.8:1 and R=3.65:1.
Clutch: Upgrading the stock clutch to a stronger one should be done either during your build or as soon as your stock one starts to fade. A good performance clutch will handle the stress of off-road use with less slippage and more power to the wheels.
3 Speed Automatic: The 3 speed automatic transmission used in Suzuki's is also considered to be a strong transmission. It is called a 3L30 or TH180 and was also used by GM in the Chevette. It has a lock-up torque converter and gear ratios of  1=2.40:1, 2=1.47:1, D=1.0:1 and R=2.0:1
4 Speed Automatic: The 4 speed automatic is also a good transmission. It is called a 03-72LE and is also used by Kia in the Sportage and Sorento. It also has a lock-up torque converter and gear ratios of  1=2.83:1, 2=1.49:1, 3=1.0:1, D=0.73:1 and R=2.7:1"
http://www.boondoxmotorsports.com/zuk_drivetrain.html
« Reply #34 on: September 17, 2008, 02:13:35 PM »
You also have two different rear ends though.  A 12 bolt and 8 bolt (or is it 10?), so the ring gears will not necessarily swap between different Tracker/Sidekicks.  Trail Tough is a pretty good source for info, I hear they do some after market work with the Suzuki's.  Might just be a rumor though.  :)
And with this, I'm officially ending my support of this thread, as amusing as it's been.  Unless your looking to grind custom gears out of a block of marble you picked up last weekend knowing the diameter really isn't going to do much good.  :P
