1991 2-Door 5-speed Sidekick Ring & Pinion Gears
  • 34 Replies
  • 14204 Views
Re: 1991 2-Door 5-speed Sidekick Ring & Pinion Gears
« Reply #15 on: September 13, 2008, 05:12:15 AM »
As the following webpage shows, the Calmini R & P Gears for Sidekicks/Trackers have been "Temporarily Discontinued", & also, the following webpage also shows that R & P gears were NOT offered for the 10 Bolt '89-'92 Rear:
http://www.puresuzuki.com/Ring%20&%20Pinion.htm
10 bolts were available in the past. I picked up a set of 5:83s but had to swap to a 10 bolt carrier in the rear.
« Reply #16 on: September 13, 2008, 11:47:58 AM »
Quote from "susan_4X4" at Zuwharrie.Com BBS:
According to the following thread, the GV and XL7 front R & P gears fit Samurai carriers without the need of cans and spacers:
http://bbs.zuwharrie.com/content?topic=59414.0
Original Post:
http://bbs.zuwharrie.com/content/topic,3975.0.html
REPLY from "Whitfield" at Zuwharrie.Com BBS:
Actually the design of the post was to get a Steel 5.125:1 geared housing into a Kick or Sammy.  The Complete GV steel front unit will change into either a Samurai axle or a Tracker front axle.  NOT that the Gear Dia or thickness would be a direct swap into a Steel Sammy carrier.  I would bet the GV ring gear would still need the can and spacer.
REPLY from "doughnutzuki82" at Zukikrawlers:
the tracker front thirds will bolt directly in place of the sami unit but people have had issues with the aluminum section cracking. the gear carrier in the tracker unit is not as strong either. the best route for one to go would be to put tracker front gears in the samurai third members and to use the can/shim kit with them. this is providing that the gears are used units and not new replacement gears.
__________________
well i thought it was in good shape, blew the rings in the bacl two cylinders tuesday, ssshhhhh*******TTTTTTTTTTT!!!!!!!!!!!!!!!!!!!
REPLY from "skyhiranger" at Zuwharrie.Com BBS:
the later trackick (99 and up) gears are cut differently.
« Reply #17 on: September 14, 2008, 04:36:18 PM »
Quote from: susan_4X4;262056
There's a good recently revised thread at the following URL on 89-98 Trackick R & P gear ratios that's based on year, body style, engine, & tranny combo, & that also gives the following tooth count:
4.30 gears have a 10/43 tooth count
4.625 gears have an 8/37 tooth count
4.875 gears have an 8/39 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
5.833 gears have a 6/35 tooth count (Calmini)
http://bbs.zuwharrie.com/content/topic,73437.0.html
Because of "Topic Merge", the CORRECT URL should be:
http://bbs.zuwharrie.com/content/topic,15579.0.html
« Last Edit: September 15, 2008, 05:23:19 AM by susan_4X4 »
« Reply #18 on: September 14, 2008, 05:51:17 PM »
Wow... that is a lot of posts.  I assume your looking at putting the gears from a Tracker into a Samurai.
First, my opinion.  Don't.  Unless your planning on putting in a hybrid rear housing or you have a pair of Trackers to swipe the front gears from it's not worth it.  If I was doing thing all over, I would have just bought some transfer case gears.
Putting Tracker gears in a Samurai:
  • The front diff from a Tracker is a direct replacement for a Samurai.  But as mentioned earlier, it is aluminum and can break.  I ran one for over a year and didn't have a problem.
  • The 89-95 Trackers have 22 spline side gears.  This will go in the stock Samurai front end.  Most heavy duty front axle shafts, like the ones from Trail Tough (still on sale!  woot!), have 26 spline matching the rear end instead of the 22 spline.
  • The 96-98 Tracker have 26 spline side gears, this will drop directly into the Samurai rear end or a front end with heavy duty axle shafts.
  • If you want to use the Tracker gears in a Samurai steel differential case you will need an adapter plate.  This is because the Tracker ring gear is thinner then the Samurai one.  Basically you are adding a giant washer to make everything line up properly.  This ring is available from most retailers.  I like Hawk Simply Suzuki myself.  If you want to do this swap, call them and tell them what parts you have and they will ship you a box with everything you need for the swap.
As for the "140% reduction" for the Samurai transfer case, this is true.  Stock ranges for the samurai transfer case:
High Range - 1.409:1
Low Range - 2.268:1
One of the nice things about the Samurai transfer cases is putting in the crawler gears also drops your low range, helping you run the bigger tires on the road.  Here is a list of the kits + high range reduction.
  • Low Ratio - High Range Reduction
  • 4.16:1 - 12%
  • 4.89:1 - 18%
  • 5.14:1 - 18.2%
  • 5.8:1 - 18.2%
  • 6.5:1 - 20.2%
  • 8:1 - 24%
« Last Edit: September 15, 2008, 12:44:59 PM by Drone637 »
« Reply #19 on: September 15, 2008, 11:11:08 AM »
High Range - 1.409
Low Range - 2.268
Uhhh....wrong.
Better go back and refigure the samurai tcase high range reduction......it isn't 140%. ::)
« Reply #20 on: September 15, 2008, 12:43:24 PM »
High Range - 1.409
Low Range - 2.268
Uhhh....wrong.
High Range - 1.409:1, so it's a 40% reduction.  better?  :P
« Reply #21 on: September 15, 2008, 01:19:02 PM »
High Range - 1.409
Low Range - 2.268
Uhhh....wrong.
Yep. ;)
« Reply #22 on: September 15, 2008, 02:25:10 PM »
"susan_4X4" wrote at Zuwharrie.Com BBS:
#2.  I thought that the stock transfer case gear ratio for a 1991 2-Door 5-speed Sidekick was 1.0 in high range, & 1.85 in low range.  Am I wrong??
"Whitfield" wrote at Zuwharrie.Com BBS: [with grammar corrections]
#2.  Yes, you're correct.
"skyhiranger" wrote at Zuwharrie.Com BBS:
yes, you are wrong
"skyhiranger", what are the stock transfer case gear ratios for a 1991 2-Door 5-speed Sidekick in high & low range??
« Last Edit: September 15, 2008, 07:00:34 PM by susan_4X4 »
« Reply #23 on: September 15, 2008, 02:47:45 PM »
What are you trying to use these gears for?  Are you building up a Samurai with a Tracker drive train, or just looking to mod up a Tracker?
« Reply #24 on: September 15, 2008, 04:45:09 PM »
yes, you are wrong
Do a search, you can find the answer.
« Reply #25 on: September 15, 2008, 08:41:22 PM »
Quote from: susan_4X4:
yes, you are wrong
According to the following URL, the stock Suzuki transfer case low range gear ratio is 1.81:1:
http://www.boondoxmotorsports.com/zuk_drivetrain.html
« Last Edit: September 15, 2008, 08:48:01 PM by susan_4X4 »
« Reply #26 on: September 15, 2008, 10:37:35 PM »
The Samurai and Tracker are completely different vehicles.  The only thing that easily be swapped between them is the front differential gears.
If you tell us what you are trying to do, we can help you out.  Otherwise it just looks like a bunch of cross postings.
« Reply #27 on: September 16, 2008, 06:44:21 AM »
I told her the same thing shortly after she started this post.  She just seems interested in getting as many answers as she can and cross-posting.....annoying as shit isn't it?......totally worthless thread.
I am not giving her any more answers until she tells us what she is doing.
BTW susan, 1.81 is wrong too.....close, but not exact. ::)
Offline locjaw
  • 2045
  • 22
« Reply #28 on: September 16, 2008, 07:28:47 AM »
i'm confused  ???  ???  ???
Offline pepatt
  • 174
« Reply #29 on: September 16, 2008, 08:11:43 AM »
Words, words, words............ ???
pepatt
