ruff idle??
  • 1563 Views
Offline Eden1
  • 73
ruff idle??
« on: September 09, 2008, 08:12:22 PM »
So i have a 1.6 tracker and it has a miss when idling????Ive changed the cap,wires,plugs,coil?It seems to run fine and has all power it only does it when its idling.Any ideas guys?Ecm maybe or could it be the plug gap?What is the gap on those?
thanks all
Re: ruff idle??
« Reply #1 on: September 10, 2008, 03:14:10 AM »
If it's fuel injected just after the air box disconnect the ducting from the air box and you should see a butterfly valve if it is black and dirty in there around that butter fly valve take a rag and sensor safe carb cleaner and clean that black stuff out of there and that should solve your problem. I had a car that did the same and I did that and it was good to go. Hope this helps.
Offline Eden1
  • 73
Re: ruff idle??
« Reply #2 on: September 10, 2008, 06:04:23 AM »
its a 1992 and i forgot to say ive cleaned the whole air intake.thanks for the input
Offline pepatt
  • 174
Re: ruff idle??
« Reply #3 on: September 10, 2008, 02:11:58 PM »
Not to question your diagnosis, but are you sure it's a miss? Meaning are you sure it's an ignition issue? Have you pulled the plug wires one at a time to see if it is one particular cylinder?
It sounds to me like a vacuum line problem. Those little bastards can cause stuff like that and are easy to miss. >:(
Spark plug gap is .028", but honestly, I changed the plugs when I bought mine and they were .040 :o and it still ran/idled smoothly (runs better now,though!)
pepatt
Offline Eden1
  • 73
Re: ruff idle??
« Reply #4 on: September 10, 2008, 04:43:57 PM »
that sounds like an idea.how do i go about checking the vaccum hoses???theres enuf to plumb my camper under the hood.lol.maybe soap and water and look for bubbles???
Offline pepatt
  • 174
Re: ruff idle??
« Reply #5 on: September 10, 2008, 05:18:20 PM »
Not unless you are trying to wash out the internals of that motor.  ;) Vacuum, remember?
Vacuum lines are almost always little 1/4" hoses. Just check all the little hoses going here and there. Look for anything not connected. If you find one hanging loose, look for a nipple it belongs to. Look for cracks in the hoses - they get old and brittle If you find some use electrical tape to seal it off and see if it fixes the problem, then replace the hose ASAP.
pepatt
Re: ruff idle??
« Reply #6 on: September 11, 2008, 01:47:20 AM »
True didn't think about vac lines but could def be the culprit.
Offline Eden1
  • 73
Re: ruff idle??
« Reply #7 on: September 11, 2008, 05:58:25 AM »
So what if the hoses are hooked up to the wrong nipples?i got a ton of that hose so im just gonna replace them all.Ill let you know.
95sidekick
Re: ruff idle??
« Reply #8 on: September 11, 2008, 08:03:49 PM »
to find a vacuum leak just get brake cleaner or carb cleaner an spray around the engine if there is a leak the engine will have a dif pitch to it when your around the area. then just look for the leak
