sreering stabilizer
  • 1452 Views
sreering stabilizer
« on: September 02, 2008, 07:22:52 PM »
anyone have pictures of new steering stabilizer setup  for my sammy with 33' tsl with 15" of lift, can i go custom or does someone have a setup? my stock is not enough I need 2 more stabilizers.
Re: sreering stabilizer
« Reply #1 on: September 03, 2008, 11:58:46 AM »
You might be able to just go with a really heavy duty stabilizer off of a larger truck instead of putting multiple stabilizers on.
Are you sure your running 15" of lift?  I have 33x12.5 on my SJ and only run 5" of lift on it.
One method is just to mount the steering stabilizer to the axle and your tie rod.  Quick and easy, but it will get some rock rash.
« Reply #2 on: September 03, 2008, 12:03:25 PM »
Why do you think that you need two more stabilisers (3 stabilisers?)? Are you sure that your geometry is correct?
« Reply #3 on: September 03, 2008, 02:34:20 PM »
Shouldn't need that kind stabilizers - something else is wrong.
« Reply #4 on: September 04, 2008, 09:35:48 AM »
I HAVE 12-15" OF LIFT, I JUST NEED A HEAVY DUTY STABILIZER (DID MORE RESEARCH)  LIKE AN OLD MAN EMU, JUST DON'T WANT TO SPEND $70, BUT SAFETY OUTWEIGHS PRICE, THANKS FOR THE HELP
« Reply #5 on: September 04, 2008, 10:18:47 AM »
If you just want a heavy duty stabilizer go down to your local parts store and pick one up from a mid-80's 1-ton Chevy Pickup.  That should be more then strong enough to handle whatever you throw at it.
The only reason I was questioning the 15" of lift is usually that is for 44" tires or more.  You mentioned you where only running the 33" tires so it seemed a bit off and I just wanted to make sure.  :)
