power steering
  • 1686 Views
Offline stuckinarut
  • 40
power steering
« on: September 01, 2008, 06:21:53 PM »
Are kicks and tracker power steering set ups the same and how hard are they to mount in a sammi.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: power steering
« Reply #1 on: September 01, 2008, 09:03:41 PM »
The set ups are the same but I wouldn't know what is needed to install it in a Sami. Maybe one of the other Sami guys will give you some ideas.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Re: power steering
« Reply #2 on: September 02, 2008, 05:37:27 AM »
They are pretty easy to mount to a sammy using a kit like the one from Trail Tough. One of the top mods to do in my opinion.
Re: power steering
« Reply #3 on: September 02, 2008, 11:42:25 AM »
Samurai = V pulley, kicks are ribbed belt, so the pulley needs to be changed. Need a bracket. What sized tires you running, and what conditions?
Offline ROSS
  • 1412
Re: power steering
« Reply #4 on: September 02, 2008, 11:46:24 AM »
most of the kits come with pulley , brackets , belt , and bolts needed
Offline stuckinarut
  • 40
Re: power steering
« Reply #5 on: September 02, 2008, 12:35:09 PM »
I have 33" boggers with 90% tread a locker up front and a mini spool in the back.I fine in the mud but this weekend I went to RC for the first time and found steering a little hard on the rocks.I have a complete 91 tracker with a 8v I could get the parts from..
Re: power steering
« Reply #6 on: September 03, 2008, 02:52:57 PM »
33" aired down will nuke a trackick setup quick if you don't run an oil cooler. Not all kits include this. the lines & cooler should be $30 - $40 on ebay / junk yard / online.
