Trackota YJ - SAS Project Pictures
  • 85 Replies
  • 33821 Views
  • 6558
  • 64
Re: Trackota YJ - SAS Project Pictures
« Reply #60 on: February 15, 2010, 12:15:07 PM »
Are those billstein 5125's? Those are pretty stiff.....
Um, what application and valving?
Offline jawman
  • 406
  • 1234
« Reply #61 on: February 15, 2010, 06:53:01 PM »
when do you think the kit will be on the market?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
« Reply #62 on: February 16, 2010, 07:26:05 AM »
My best guess is the month of march. I have no clue to what it will cost either. Lets not hope its anywhere near the trail slayer kit....... id rather have a second sidekick then pay that much....id stick 2 ifs and sell my axle.
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
Offline Minmatar
  • 262
« Reply #63 on: February 16, 2010, 07:28:50 AM »
I know the 5125 goes to 170/60 but i've seen them as high as 366/240 way over kill
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #64 on: February 17, 2010, 09:09:03 AM »
hey what did you do for a drive line? did you use a spacer or had one made
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #65 on: February 17, 2010, 07:13:25 PM »
 I wonder if they are using kick or toy driveshafts? Kick shafts can be used to keep it cheap, but need a slip yoke elimintor to have lots of travel. But if using a sammy tcase, then front sammy driveshafts could be shortened for that apllication, or common aftermarket sammy driveshafts.
Offline Minmatar
  • 262
« Reply #66 on: February 18, 2010, 10:26:00 AM »
To be honest id go with custom drive lines Suzuki 2 Toyota. = UJ 2 CV. I think it would be my best bet after turning the front axle 15 deg counter clock wise. Pointing the 3rd member to the offset samurai T case.
Offline Amilla
  • 1076
« Reply #67 on: February 18, 2010, 10:29:49 PM »
Are you planning on cutting and rotating the knuckle balls?
The 1st and 2nd generation Toyota drivelines fit up to a Samruai T-cases quite well.
Amilla
Offline Minmatar
  • 262
« Reply #68 on: February 19, 2010, 09:39:16 AM »
Amilla
Yeah Ill cut them with a 4" pipe cutter. And rotate them myself. Im going to take them to a shop to be welded correctly though. I dont have that much faith in my welding skills. I'll leave that to the pro's. Im fine with welding other items.
Im sure ill get a ton of welding time in with this kit though.
Offline Minmatar
  • 262
« Reply #69 on: March 01, 2010, 12:08:29 PM »
Sad to say that sky is so backed up this kit has been put on the back burner. Looks like ill be making my own kit. Really sad to hear that but 6 months out does not work for me.
Broke my heart.....
Looks like we might have a new thread on SAS SOA coming soon. Just need to find out what direction to take with the mounting points for the leaf's.
Offline jawman
  • 406
  • 1234
« Reply #70 on: March 02, 2010, 04:49:48 PM »
Amilla
for some reason I have never thought about having to cut the knucles if I rotate the third member to grt a better driveline angle. does anyone have any more info on how to do this???
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Minmatar
  • 262
« Reply #71 on: March 03, 2010, 07:59:06 AM »
Amilla
Here ya go This is my guide on rotating the knuckles
http://www.4x4wire.com/toyota/tech/rotated_housing/]
[url]http://www.4x4wire.com/toyota/tech/rotated_housing/
[/url]
Offline jawman
  • 406
  • 1234
« Reply #72 on: March 19, 2010, 09:57:26 PM »
sounds easy, but my axles are fj55 axles, so I  don't know if they are built the same. with the way the knuckle goes into the axle housing.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Minmatar
  • 262
« Reply #73 on: March 22, 2010, 09:39:19 AM »
Im sure its the same since toyota has always favored birfields. Sad to say this kit is on the back burner which will drive me to get the calmini lift......for now im just referbishing the axles im keeping and gathering parts and saving money for a second zuk
Offline jawman
  • 406
  • 1234
« Reply #74 on: April 02, 2010, 10:35:16 PM »
I have got a couple nice zuks for you
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
