My new rear bumper and rear stinger
  • 21 Replies
  • 8148 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: August 28, 2008, 08:33:31 PM »
I started out with a piece of 4x2 steel and welded on a piece of 1x2 to get the height that I was looking for. I then used some more of the 4x2 and made the corners to fit. What do you guys think?
    Kevin
   Ps I also raised the gas tank while I was there. Granted I only have a 2" body lift so I did it a little differnt.
« Last Edit: April 21, 2009, 09:25:08 AM by ppltrak »
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: My new rear bumper
« Reply #1 on: August 28, 2008, 08:35:45 PM »
Some more pics
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: August 28, 2008, 08:40:15 PM »
The Jonny Joints went on the rear trailing arms, I had already put a jonny joint in the upper link awhile ago and I like how it works so I decided to use them on all the rear links. Oh and this is in the works for my spare tire.
   Kevin
Offline Freak
  • 129
    • Freakreation
« Reply #3 on: August 28, 2008, 09:05:11 PM »
Nice work, clean and simple I like that. I'm doing a similar tire carrier for my sammy
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
« Reply #4 on: August 28, 2008, 10:43:48 PM »
I will take one in black please.  8)  nice looking bumper!
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
« Reply #5 on: August 29, 2008, 07:22:45 AM »
   Kevin
Any photo's of this work?  I have been considering changing to a four link, using stock forward mounts.  So I am very interested in the results of your work.
Nice work on the bumper.  I look forward to your spare tire mount also.  I made a similar bumper (no body lift), and currently have the spare back on the door (not very convient).
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #6 on: August 29, 2008, 09:19:16 AM »
I'll get some pics. soon of the whole setup.
    kevin
Offline RHodge
  • 523
« Reply #7 on: August 29, 2008, 05:03:13 PM »
THE REAR BUMPER LOOKS NICE
Ryan
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #8 on: September 06, 2008, 07:30:17 AM »
Brd hunter the pics of the jonny joint rear setuo is on the regular forum under New front coils.
  Kevin
Offline 91zukisas
  • 140
« Reply #9 on: October 12, 2008, 07:17:43 PM »
look good. Looks like it could take a beating.
91 2door Sidekick yota Axels  SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project :D
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
Offline madmark
  • 30
« Reply #10 on: October 14, 2008, 08:33:11 PM »
Another graet looking bumper,man you guys do good work!I used to be a welder but after 4 heart attacks in 2 years I buy my stuff.I don't ever want to feel that kind of pain again,It's probably only a matter of time though.
86 samurai,29x10.50x15 tsl ssx's,my-side2,44mm hd carb,DT header soon to have yj missing links,zor front bumper,rro rear bumper
91 tracker,30x11.50x15 tsl ssx's,tub front bumper
Offline SNJSamurai
  • 386
« Reply #11 on: October 20, 2008, 08:56:20 PM »
wow professional looking and stylish   4 thumbs up
Bob
Offline Hawkeye Huey
  • 92
« Reply #12 on: October 21, 2008, 08:38:08 AM »
Hey, I like the idea of a stinger type tire bracket, What do you think about making brackets that fit above the tail lights. Another manifacture utalizes this point for roof rack support. why not? any thoughts?
1990 GEO Tracker hardtop, 3" bod, 3.5"susp, rebuilt engine, Hawk SS torquer cam,Thorley tri-y 2 1/2" pipe, TT rockmonster T-case, Lockright F/R, 5:38 R/P, Pro-comp series 51 wheels 31" GY MTR's
« Reply #13 on: October 21, 2008, 09:39:41 AM »
My only problem with this is when you hit something your body is going to buckle.  If you added some extra bracing on the back side that went to an internal roll bar it would probably work though.
  • 92
« Reply #14 on: October 21, 2008, 05:02:08 PM »
Good point, I did not think of that. Back to the drawing board.
