starter problem
  • 886 Views
Offline scooterszuk
  • 20
starter problem
« on: August 25, 2008, 09:48:30 AM »
hey guys and gals.
I have a problem with my 88 samurai starting, you could get out and hit the solenoid with a hammer and it would start. I had been traversing a lot of mud and water, so i figured the solenoid was the culprit. |removethispart|@ auto zone a starter was 89.00 and the solenoid itself was 64.99 so i got and changed the starter, the solenoid clicks now, you can hear it when you turn the ignition switch, but you have to turn it sometimes 3 to 4 times to get it to roll over. The battery has been charged, cause i thought it was the problem before i started tapping on the starter solenoid. I have saw a sticky starter relay fix on the internet and wondered if this is the fix for my problem. thanks for all your help guys and girls.
Re: starter problem
« Reply #1 on: August 25, 2008, 09:54:08 AM »
When mine would start doing that I would just pull my key out and spray some electrical cleaner in the hole where the key was and it would fix it for a while. so bad ignition switch?
