shake in the front end
  • 1812 Views
Offline delriowil
  • 28
« on: August 23, 2008, 10:02:24 AM »
I did a SPOA and now have a shake in the front end. I can not find what is doing it. I have had my tires rebalanced. but still shakes horrible even at slow speeds. any ideas of what is causing this. could it be the angle of the drive lines to the front axel making it do this.
I,m new at the Zuk thing, but I think I am figureing it out.
Offline ROSS
  • 1412
Re: shake in the front end
« Reply #1 on: August 23, 2008, 11:59:15 AM »
how's the allignment???
Offline RHodge
  • 523
« Reply #2 on: August 23, 2008, 01:00:08 PM »
Is everything tight,  you also might want to look |removethispart|@ the shackle & spring bushings in the front,
did you change the streering, could be bad tierods, or kingpin bearings
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: August 23, 2008, 02:45:14 PM »
...could it be the angle of the drive lines to the front axel making it do this.
If you changed the pinion angle on the front differential, you created two problems:
1  A radical change to the caster angle that  will make the truck difficult to steer.
2. If the operating angle of the u-joints are not identical you will have vibrations.  This is caused by pointing the differential up at the transfer case on either driveshaft instead of trying to match the factory pinion angle.
For more info on the above, do a search for driveline at Ack's FAQ (the link is in my signature).  The bottom two links are what you need to check out.
Then there is the dreaded "out-of-phase" driveshaft!
If you do not properly assemble either driveshaft (assuming that you pulled them apart at some point) they will cause vibrations and, if not properly re-assembled, will destroy the U-joints.  check out the following links:
http://bbs.zuwharrie.com/content/topic,16725.15.html (for the bandwith-challenged).
http://www.acksfaq.com/driveshaftvideo.php  The video version...
I hope that this helps!
Ack
Offline delriowil
  • 28
« Reply #4 on: August 25, 2008, 03:29:20 AM »
Thanks guys, I will look at some of these today when I wake up.
Wil
« Reply #5 on: August 25, 2008, 03:37:19 AM »
 ;) Wow, you can read and type in your sleep? Cool!
Offline ROSS
  • 1412
« Reply #6 on: August 25, 2008, 07:59:27 AM »
I know alot of people that do that at work everyday
Offline delriowil
  • 28
« Reply #7 on: August 26, 2008, 10:00:52 AM »
Funny guys, I work nights. 4 to 4 shift.
« Reply #8 on: August 26, 2008, 03:51:13 PM »
 :laugh:
