T-case rear output bearing???
  • 1283 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: August 22, 2008, 01:29:12 PM »
I need to replace the output bearing on a 93 kick. The yoke and bearing have gave up the ghost. Can I just remove the back part of the T-case and press out the bearing, then do the opposite to install? Or do I have to remove the whole case and split it on the bench. Any help would be great.
    Thanks
     Kevin
Offline RHodge
  • 523
Re: T-case rear output bearing???
« Reply #1 on: August 22, 2008, 02:09:43 PM »
I've always found it easer to take something out rather then laying on my back trying to fix it.
Ryan
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: August 22, 2008, 02:10:50 PM »
I have a lift ;)
  Kevin
Offline J-Ron
  • 50
  • when in doubt, straighten it out
« Reply #3 on: August 22, 2008, 09:33:07 PM »
I recently did the 6.5 : 1 t-case gears and i believe the rear output bearing is impossible to get out without dropping the entire t-case. cause the output assembly has a snap ring holding it together and i needed a hydraulic press to get the bearings off.
here's a pretty good illustration http://trail-gear.com/tech/zuk65gears/index.html
« Reply #4 on: August 22, 2008, 10:06:37 PM »
I think he is talking about a tracker t case, it has a needle bearing that has to be pulled from the back.
Offline J-Ron
  • 50
« Reply #5 on: August 23, 2008, 11:51:22 AM »
well it's all greek to me then....
