Broken moter mounts
Broken moter mounts
ppltrak
654
zukspeed staff
Broken moter mounts
August 20, 2008, 10:59:43 AM »
I keep breaking moror mounts on my kick. 8v eng 94 year has anybody else had this prob. If I wheel hard they only last 1 trip.
Kevin
94 purple/green splash tracker w/ calmini 3' heavly modified lift 32 11.5 r15 bfg m/t's & custom air induction and header w/ 2"exh. no cat lockrite rear 2" B/L and a heavy right foot and now 583s steel up front and locked.
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Re: Broken moter mounts
August 20, 2008, 01:02:55 PM »
I've seen you drive
I run the heavy duty ones from TT
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
86badboy
15
believe it!
August 20, 2008, 05:48:49 PM »
teh full circle mounts are supposed to be awesome. they also use spring bushings so they are cheap to build.
BUILT NOT BOUGHT
86 sami, spoa, RUF w/ML's, 5.14 t-case, rear lockright, 33x12.5 mud T's, rear disk brakes, custom bumpers, custom lighting....list goes on.....
Blake
ppltrak
654
zukspeed staff
Reply #3 on:
August 21, 2008, 07:46:10 AM »
Who makes the full circle mounts? Will they work on a Kick?
Kevin
ROSS
1412
Reply #4 on:
August 21, 2008, 08:39:20 AM »
petroworks does for the sammi conv. . call and see about the kick
http://www.petroworks.com/drivetrain-accessories.php
rascott
669
15
tread lightly monkeywrench a little
Reply #5 on:
August 21, 2008, 10:58:34 AM »
i understand some people are using 318 dodge pickup mounts.
ppltrak
654
zukspeed staff
Reply #6 on:
August 22, 2008, 01:50:26 PM »
My problem right now is that the oil pan is too close to the steering drag link. Something is not right.
Kevin
ppltrak
654
zukspeed staff
Reply #7 on:
August 25, 2008, 07:49:14 AM »
Has anybody used the HD motormounts?
Kevin
Ps the dodge 318 mounts are only 1.5" wide and the stock mounts are 2.5"
ROSS
1412
Reply #8 on:
August 25, 2008, 07:57:21 AM »
i've been running them for several years now. haven't broke one yet. knock on wood
safarikick
270
nor-cal rhinos
Reply #9 on:
August 25, 2008, 07:08:09 PM »
can you use the dodge motor mounts i a kick with a 16v
86badboy
15
believe it!
Reply #10 on:
August 25, 2008, 07:53:55 PM »
anything is possible with a lil cut and weld...
BUILT NOT BOUGHT
Blake
blackandtan
27
Reply #11 on:
August 26, 2008, 05:05:14 PM »
You can also fill the stock mounts with 3m window weld, its a very strong urethane that bonds to rubber well, it tries to a rubber like consistency. works great for stiffening up motor mounts, have used it on most of my vehicles for years.
ppltrak
654
zukspeed staff
Reply #12 on:
August 26, 2008, 05:25:19 PM »
I tried to order some HD motor mounts from Low range but he called his supplier and they don't make any for 92 and later kicks. So whats the deal, is a heavy duty motor mount not available? I guess I'll just have to fab up some full circle mounts. I do have some rear control arm bushings but I think that I'll get some bad vibes if I use them.
Kevin
