What Carb should i use
Wilsami
August 18, 2008, 07:36:47 PM »
Hello everyone,
I recently purchase an 87 Sami, and am rebuilding the engine. I was wondering if anyone had any suggestions on what type of carb i should run and if you a running a specific type how do you like it.
samwisper
76
2
Re: What Carb should i use
August 18, 2008, 09:32:23 PM »
Im running a toyota corolla carb seems to work will. Just took it on a run and worked assume. It comes on 74-78 1200 corollas. Slight mods to spacer plate because primary hole slightly larger.Pretty much bolt on hook up all vac. lines idle solenoid. Looks aimost stock.Even pasted smog with it.Good luck with your choice.
Amilla
1076
Toyota running gear was made for a samurai!
August 19, 2008, 10:02:10 AM »
A lot of people have been liking side draft carbs.
theres a couple vendors producing them now, not smog legal. But i have heard that it is quite the boost in power, and no more stalling out at steep angles.
Amilla
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Reply #3 on:
August 19, 2008, 12:16:33 PM »
two words
FUEL INJECTION
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
phloop
Reply #4 on:
August 19, 2008, 08:27:54 PM »
Two more words
MySide
or
MySide2
. Check out
http://www.zuksoffroad.net/samurai_engine.htm
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #5 on:
August 20, 2008, 09:59:07 AM »
gotpropane.com
WAY simple system.
