leaking differential |removethispart|@ front wheel steering knuckles
  • 1634 Views
Offline scooterszuk
  • 20
Hey changed the starter on my samurai and saw some leaking differential oil at the tire on passenger side, my question, can you replace the felt seals with out buying a whole front axle rebuild kit, there is no poping or anything, it has been driven in mud alot. if you can buy just them, where can you buy a kit.
Offline ROSS
  • 1412
Re: leaking differential |removethispart|@ front wheel steering knuckles
« Reply #1 on: August 17, 2008, 06:38:07 PM »
call HAWK  1-888-SAMURAI
« Reply #2 on: August 17, 2008, 08:06:14 PM »
I'm with Ross.  But your axle seal is probably bad, so you will probably want to replace that as well.
Offline ROSS
  • 1412
« Reply #3 on: August 17, 2008, 08:32:18 PM »
I checked mine by pulling the felt seal then lift up the opposite side and see if you get alot of oil
they are easy to change if it is bad
« Reply #4 on: August 18, 2008, 11:04:25 AM »
Ya there should only be grease behind the felt seal, you will have to pull the axle to replace the oil seal.
« Reply #5 on: August 18, 2008, 12:11:55 PM »
Hah!  Oil Seal!  I couldn't remember what the name was.  :P
