distributers?
  • 1246 Views
Offline Jimzuki
distributers?
« on: August 14, 2008, 05:19:36 PM »
I'm swapping a '91 tracker 1.6 in to my sammy. I'm going to swap intakes and keep my weber. Will my 1.3 diatributer swap to the 1.6? with an electric fuel pump and adaptor kit I think I have everything else I need for this swap.
Jim
Re: distributers?
« Reply #1 on: August 14, 2008, 05:22:44 PM »
Which 1.6?
Offline Jimzuki
Re: distributers?
« Reply #2 on: August 14, 2008, 05:26:15 PM »
suzuki 1.6 8v efi
Re: distributers?
« Reply #3 on: August 15, 2008, 05:01:29 AM »
The 1.3 dizzy will swap onto the 1.6 but you will need to swap the 90 deg housing/adapter too. For some reason the shaft on the 1.3 is longer than the one on the 1.3.
Re: distributers?
« Reply #4 on: August 15, 2008, 09:43:49 AM »
I believe the shaft is the same length... it's the little "nipple" at the end of the shaft that's different. (stop giggling kids). The 90 deg housing for the sami has a hole this 'nipple' fits into. You can either swap in the one from the sami, or clearance the 8v.
Offline Jimzuki
Re: distributers?
« Reply #5 on: August 15, 2008, 03:25:39 PM »
Thank you,
so I can take the housing and ditsy off and swap right on to the 1.6. Kewl!
Jim
Re: distributers?
« Reply #6 on: August 17, 2008, 11:58:00 AM »
Suzuki's like Toyota - they like to keep things modular.
