intake from calmini
  • 1532 Views
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
intake from calmini
« on: August 12, 2008, 06:43:34 PM »
I just installed my new calmini air intake system and iv been driving around with it for about one month, and i love it. but however now its broken. It broke right were it bolts to the body. I believe it broke because the rubber sleeve does not move/absorb the vibration of the motor when it rocks back and forth. thus braking the mounting point. What can i do to fix this ???  thanx for the ideas
http://www.puresuzuki.com/air_intake_system.htm
« Last Edit: August 12, 2008, 06:47:09 PM by SunrunnerGT »
Sunrunner GT, Gold Trim Level
Re: intake from calmini
« Reply #1 on: August 12, 2008, 07:01:14 PM »
Epoxy or a welder.
« Reply #2 on: August 13, 2008, 04:29:16 AM »
Return for warrenty replacement?
« Reply #3 on: August 13, 2008, 05:59:12 AM »
Make sure you don't have a broken motor mount.
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #4 on: August 14, 2008, 03:23:15 PM »
I was thinking about replacing the rubber tube with a stock style tube that allows the motor to move, and will not push/pull the air filter assembly back and forth.
Offline ROSS
  • 1412
« Reply #5 on: August 14, 2008, 03:30:02 PM »
the motor shouldn't move enough to break anything.  double check the mounts
I had a broken one for probably a year and didn't even know it till I pulled the motor
« Last Edit: August 14, 2008, 03:31:38 PM by ROSS »
