Thank you very much for the info, Im gonna run the grinded out version first, I already got the rear stock one shortened so I just have to finish grinding it, in the mean time, I will start on the toyota shaft. I was thinking, instead of machining those plates, Ill just take a toyota flange off the t-case I got from a pickup and weld it to the tracker slip and then tap the shaft..... that should work....
Thanx again
