tracker gearing??
tracker gearing??
Tracker-Kid
50
tracker gearing??
July 17, 2008, 05:38:29 PM »
hey guys just got one Question? can you put gears in the t case in a 94 4x4 tracker that has 3 speed auto?? just want to gear down the low end?
thanks guys
Mikka
IF ITS BROKEN..... WELD IT!!
wildgoody
8134
67
Re: tracker gearing??
July 17, 2008, 05:44:23 PM »
Yes, they are available from several vendors, between 600 and 800 last
I checked. This will only lower low range, not high range.
Drone637
8121
116
Evil Cow
July 17, 2008, 06:29:43 PM »
To drop the range in high range you need to change the gears in the diff. Since you have an auto you can get the gears from a manual rig easily enough. There was a post a while back that gave every model and what range it had in it.
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #3 on:
July 18, 2008, 02:39:03 AM »
Or, go kicker 3 (samurai t-case behind your t-case) for 1.4 (40%) reduction.
