chevy emblem removal
  • 10 Replies
  • 2267 Views
Offline clockwork
  • 19
« on: July 17, 2008, 02:01:20 PM »
so i dont want my tracker to have the chevy bowties on it anymore and i was thinking of ways to take them off.
what would i use to take off the tracker name and bowtie thats stuck under the door trim on the front doors?
i tihnk they are just stuck on with the 3M vehicle tape.
just looking for suggestions so i dont ruin the paint underneath
~2000 Tracker~2.0L-16V~5spd manual~4-door~4WD~K&N air filter~Kenwood Excelon KDC-X491 CD Receiver~polk audio db650 speakers~US acoustics USX4095 amplifier~work in progress
Re: chevy emblem removal
« Reply #1 on: July 17, 2008, 02:49:03 PM »
12 Gauge shot gun with 00 Buck shot? Just kidding, try warming them up with a heat gun or hair dryer and then SLOWLEY peeling them off. They should just be held on with double sided tape.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: July 17, 2008, 03:47:12 PM »
Two way tape, do it slowly as it is really good tape. Any decals you should heat up with a hair dryer or heat gun.
To get the sticky residue off, use methyl hydrate. If it's not srong enough use WD40 - then use methyl hydrate to clean off the WD40.
phloop
« Reply #3 on: July 17, 2008, 05:20:11 PM »
Use the hair dryer to heat the tape up real good and then use a piece of fishing line to saw through the foam tape. Then use a 3M adhesive removal wheel thingie to remove the rest of the adhesive.
Offline clockwork
  • 19
« Reply #4 on: July 17, 2008, 05:21:02 PM »
thanks for the quick reply guys, ill go out and try it and tell you how it goes
Offline clockwork
  • 19
« Reply #5 on: July 19, 2008, 10:27:23 AM »
so i got them off no problem, just waiting for the goo-off stuff i put on to soak in so i can peel off all the left over tape.
« Reply #6 on: July 19, 2008, 12:15:42 PM »
What emblem are you going to put up front?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: July 19, 2008, 04:22:39 PM »
Those aren't good to use on a painted surface.
Offline clockwork
  • 19
« Reply #8 on: July 20, 2008, 09:32:48 AM »
im planning on putting the vitara grill on the front instead of the chevy bowtie, maby something else if i can get a custom fit grill made
Offline jzap
  • 515
  • How difficult can it be?
« Reply #9 on: July 21, 2008, 08:03:51 PM »
An 8 point buck at 50MPH removed the emblem from the front of my Tracker pretty effectively...   ...removed a lot of other stuff too...
This replacement grille was made from about $5 worth of 1/2 in. PVC pipe from Home Depot.
« Last Edit: July 21, 2008, 08:09:04 PM by jzap »
Jim Z.
66 Apache camper
Offline clockwork
  • 19
« Reply #10 on: July 22, 2008, 06:52:07 AM »
looks pretty good jzap, ill look into doing something like that
