clicking when hubs locked
  • 1529 Views
Offline da_mtg_man
  • 58
« on: July 15, 2008, 09:38:53 AM »
Just like the topic says, I just started hearing it click when the hubs are locked. Cv's are going bad I guess? I'm not a mechanic so are they hard to take out?
Keep in mind that I lost a pair of channel locks this past weekend when trying to get the hose clamp back on the vent line on my gas tank. I need to walk across the street into the woods and see if I can find them.  ;D
I had no idea they would fly that far.
« Last Edit: July 17, 2008, 11:35:49 AM by da_mtg_man »
Some people are like Slinkies...
Not really good for anything,
But they still bring a smile to your face when
you push them down a flight of stairs.
Re: clicking when hubs locked
« Reply #1 on: July 15, 2008, 12:48:56 PM »
Don't worry, you just have to be smarter than the part that you are working on  ;D
Offline da_mtg_man
  • 58
« Reply #2 on: July 15, 2008, 05:51:59 PM »
It's more of a patience thing rather than a smarter thing.
Chinese ancient secret " Man who want pretty nurse, Must be patient"
Now, Back on subject. Anyone
Offline Armour
  • 360
« Reply #3 on: July 15, 2008, 07:36:05 PM »
They are not too bad. You just need some special tools! Possibly allen keys for the hubs and c clip pliers for the shafts. I think. I don't quite remember! LOL
Offline da_mtg_man
  • 58
« Reply #4 on: July 15, 2008, 07:42:55 PM »
I remember pulling my back axles on my Suzuki King Quad and that was a piece of cake. I hop these are close to being the same.
Offline captchee
  • 224
« Reply #5 on: July 16, 2008, 06:11:22 AM »
just changed out mine on my 89 sidekick . no real issue other then  the  hub nut  which takes a special tool   to get off . You will also need a jack , torque wrench as well as  what Armour stated . Also get some disc break grease so as to pack the bearings while you have them exposed
 I seem to recall a post on how to make one  here on this site .
 don’t mess with the CV joints ,  for about 70  bucks a side " if i recall " you can replace the whole drive axle  which comes with new  boots and joints . While your at it and in there ,  spend a few more and replace the inner and outer seals  .
Drivers side is the simplest  but the passenger side isn’t that hard either. It just pops into the  diff   over bolting to it like the drivers side does .
« Reply #6 on: July 16, 2008, 12:22:52 PM »
You don't need to remove the hub. Place a jack under the conntrol arm, remove the FWH and the ciirclip behind it. Disconnect the sway bar if you still have it and detach the strut, at the top or bottom*. Then just swing the hub out of the way. Just watch out for dirt getting in the bearing once you've pulled the driveshaft.
*some people prefer to remove the lower ball joint instead.
Offline captchee
  • 224
« Reply #7 on: July 17, 2008, 06:45:03 AM »
 thats what i did with mine , i just dropped the lower  ball joint .
 i also replace the bearings   since i had  things apart . hence pulling the hub . .
 i figured  becouse i had  the front end up and apart , might as well put new  parts in
Offline locjaw
  • 2045
  • 22
« Reply #8 on: July 17, 2008, 08:36:00 AM »
ROTFLMAO
