a truely manual locker
  • 9 Replies
  • 2561 Views
Offline picklepants
  • 42
« on: July 14, 2008, 08:31:20 PM »
is there such a thing as a truely manual locker. one that is not actuated by an electrical or pneumatic source? just like manual locking hubs but for a diff lock
Offline RHodge
  • 523
Re: a truely manual locker
« Reply #1 on: July 14, 2008, 08:49:50 PM »
not that I've seen for the zuks, OX lockers have a cable the activates them, It doesn't,t look like the have them for any drop out third member   Zuk, ford 9" ,Toyota
http://www.ox-usa.com/ox/Products/Lockers/tabid/429/Default.aspx
Ryan
Offline picklepants
  • 42
« Reply #2 on: July 14, 2008, 08:57:23 PM »
darn well someone should make one
« Reply #3 on: July 15, 2008, 03:34:52 AM »
You could hack up the Kam locker to use a cable instead of electric if you wanted.
« Reply #4 on: July 15, 2008, 05:01:29 AM »
The origianl Kam locker was cable operated so is the OE Suzuki 'parking' locker as fitted to German models.
Offline Amilla
  • 1076
« Reply #5 on: July 15, 2008, 09:24:33 AM »
Toyota E-lockers can be converted over to cable.
Cant beat a cable!
Amilla
« Reply #6 on: July 16, 2008, 04:06:13 AM »
I actually knew that about the Kam locker.  I've never heard of the Parking locker before though.  What is that?
« Reply #7 on: July 16, 2008, 05:06:45 AM »
With the brake on the tcase the diff still allows one wheel to turn. In Germany the law requires the ebrake to work on both wheels so Suzuki fitted a cable operated locker to the rear axle. I have have seen conflicting reports on whether its suitable for use off-road. I nearly bought one once for the 410 but was warned off. I wish I had got it now, one of the Difflock boys eventually bought it to fit to his LJ.
« Reply #8 on: July 16, 2008, 12:47:16 PM »
Cool, learn something new all the time.  I can add "stock cable actuated locker" to my list of why the 410 rocks.  :P
Offline Frank84
  • 176
« Reply #9 on: July 16, 2008, 01:12:56 PM »
check out GBR Manual Diff Lock  http://www.greatbasinrovers.com/catset.html
It's for old rovers - not too much info there but it sounds like a manual hub style engagement - something a little different.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
