A/C Fuse keeps blowing
  • 2008 Views
Offline Frank84
  • 176
« on: July 11, 2008, 09:14:26 AM »
2001 Tracker -
I was driving home from work and my A/C fuse blew.  I replaced it and it blew again in 5 seconds.  Any ideas on where to begin?  Anyone else have this happen?
Thanks!
Frank
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: A/C Fuse keeps blowing
« Reply #1 on: July 11, 2008, 08:26:37 PM »
My two cents: Take your truck to a reputable garage and have them test your compressor resistance.  It's probably getting ready to take a puke on you and electrical resistance is building in it tripping the fuse.   If it is the compressor, you're probalby lookin at around $950 for a new one installed.  Those compressors are salty when they go!!!  Good luck to you.  I hope it's something easier (and cheaper) to correct
Offline Frank84
  • 176
« Reply #2 on: July 14, 2008, 07:48:42 PM »
Thanks for the suggestion.  I'd tend to agree with you on the compressor.  I unhooked the compressor clutch (electrically), put yet another fuse in, ran the A/C, then hooked back up the compressor and it seems to be working at the moment.  My guess is that it will blow again any time, but I only use the A/C when it rains since I've got the soft top.  If it is expensive to fix I'll probably just live without A/C.
Offline blacknight
  • 987
    • Gonzookin
« Reply #3 on: July 15, 2008, 07:09:28 AM »
2001 Tracker -
Thanks!
Frank
Was it raining when it blew???  The only 2 time I've  killed the AC fuse was 1 after a deep water crossing. Turned the AC back on and pop...  and 2nd after washing the front grill area out (dam mud get every where). What I found was water was getting in to the electric plug for the fan = dead fuse.
George
Offline Frank84
  • 176
« Reply #4 on: July 15, 2008, 05:33:08 PM »
It was raining!  Maybe I'll try some dielectric grease in that connection.
