body lift
  • 1103 Views
body lift
« on: June 10, 2008, 10:54:38 AM »
i am looking at getting a body lift for my samurai.  i already got a 3in calamini suspension lift. and i want the 3in calamini body lift.
what do i need to watch out for running the body lift
Offline picklepants
  • 42
Re: body lift
« Reply #1 on: June 10, 2008, 11:41:59 AM »
whats the perpose of the lift?
Re: body lift
« Reply #2 on: June 10, 2008, 12:19:03 PM »
If you're buying calmini's kit, it should come with everything required.  I'd look to see how they extend the steering shaft and shifters.
I've had bodylifts on several vehicles over the years without a problem.  Make sure you check the torque on the bolts after a few 100 miles.
Offline mic
Re: body lift
« Reply #3 on: June 10, 2008, 12:46:22 PM »
I had the Calmini kit, simply drill out the nylon pin extend the shaft and weld on a bead for the steering. The shifters didn't need to be extended.
91 Tracker Calmini 3+3 31x10.5 swamper ssr
88 samuri 3" body 2"susp. 31x12.5 boggers sold
03 super duty daily work truck $$$$gas
