Coil Spring Conversion Engineering
  • 2771 Views
Offline Dazookster
  • 61
« on: June 06, 2008, 09:32:23 AM »
Okay so I have been looking into putting coils on my Samurai.  I am curious as to how the coils stay in place I can't see how it stays on if you flex too much could the spring fall out? Or is it attached to the axle?  I have been drawing up some plans for it but the spring mounting I am at a loss as to how to do it. Any ideas or pics as to how they do this?
Wahoo for Global Warming more time to go Wheeling
Re: Coil Spring Conversion Engineering
« Reply #1 on: June 06, 2008, 09:58:17 AM »
The ones in my IFS sit in a cup under tension. I believe RRO has a coil setup & pics. Maybe you can find some stuff there?
Offline Dazookster
  • 61
« Reply #2 on: June 06, 2008, 10:36:30 AM »
Ya I looked there but couldn't see it in very much detail I guess i could use some tube that would fit inside or outside of the spring loosely any other thoughts?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: June 06, 2008, 11:56:33 AM »
You can buy a spring capture
Offline Dazookster
  • 61
« Reply #4 on: June 06, 2008, 12:28:27 PM »
Thats cool where do you buy them?
« Reply #5 on: June 06, 2008, 02:03:16 PM »
Also search for dislocating cones.
Offline Hillbillydave
  • 213
« Reply #6 on: June 06, 2008, 06:20:08 PM »
If you look into the way the early Ford Broncos were made, there is a clamp at the axle that holds the spring. As long as you limit your travel to the point where the springs always have some tension, you should be fine. I recently made some 2" spring spacers for my Sidekick, and I made them so that they captured the springs on the outside. In the back I used 91 Crown Vic shocks, and at full extension the spring will move slightly, but it will not come out. I don't have a pic yet, but I am working on it.
Hope this helps
David
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #7 on: June 06, 2008, 08:49:50 PM »
hillbillydave how did you make your spring spacers? im wanting 2" spacers for my wifes tracker and im building 2" bodylift blocks ti fit her some 31"s
Offline Dazookster
  • 61
« Reply #8 on: June 10, 2008, 08:09:51 AM »
Been doing sone more drawings and it looks like it will bind up in the front with the setup I have been looking at looks like it would bind up when i flex.  Would using heim joints instead of bushings help eliminate binding I'll be using johnny joints too.
