Anyone know if these wheels will fit a 96 Tracker 4WD?
  • 1640 Views
IrishMike
« on: May 27, 2008, 12:56:01 PM »
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEW%2D0289%2D5055&N=700+400077+303171+115&autoview=sku
Looking to purchase some new wheels and like these... Wondering if they will fit my 96 Tracker.
Re: Anyone know if these wheels will fit a 96 Tracker 4WD?
« Reply #1 on: May 27, 2008, 01:03:34 PM »
It doesn't look like you'll be able to fit the caps on the front wheels if you have freewheel hubs
phloop
« Reply #2 on: May 27, 2008, 02:55:42 PM »
You should be able to get caps to fit the front hubs.
« Reply #3 on: May 28, 2008, 03:22:45 AM »
Kind of wide at 10" though.  I run 8" with 33x12.5" tires and can't really see going with a wider wheel unless I was bumping up to a 14.5" wide tire.
Offline MUD CHILD
  • 355
  • 9
« Reply #4 on: May 28, 2008, 04:03:21 AM »
They are the right bolt pattern, but 10" is a little wide, a 7" or 8" rim would be better
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: May 28, 2008, 06:49:54 PM »
The description does not indicate the size of the center hub hole.
The hub hole size - not the bolt pattern - is what makes a lot of wheels unusuable for Samurais and Sidekick/Trackers.
Ack
Offline Jookycola
  • 372
« Reply #6 on: May 29, 2008, 07:47:51 AM »
I had those wheels on my Samurai back in the day.  They fit...or at least they made some that cleared the hubs.  When i had mine the rim shop ordered them with special center caps that had a hole in them so the hub lock could poke through.  So i know they at least used to fit and had special covers for 4WD vehicles.
  [/url]
