Nissan power steering box
  • 4500 Views
Offline RHodge
  • 523
« on: May 16, 2008, 06:27:54 PM »
I decided to put a Ps box from my old Nissan that I had laying around, after test fitting the box I found that it was a good fit and it uses four bolts to mount it unlike the Toyota that has three
after some quick measurements I started drilling some holes for the tubs to run through
The plate used to beef up the frame and mount the box to
even the pitman are will swing clear and level
after I made sure everthing fits time to weld   :)
now I'm waiting for the psc pump and bracket for the 1.6 to get here
Ryan
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
Re: Nissan power steering box
« Reply #1 on: May 17, 2008, 06:45:52 AM »
   Nice work.Good looking welds,which is a good thing.
KING ZOO!!
Offline RHodge
  • 523
« Reply #2 on: May 17, 2008, 04:25:26 PM »
thanks, it's realy cool how good the box fits the frame almost like it was made for it
Offline Amilla
  • 1076
« Reply #3 on: May 18, 2008, 09:24:26 AM »
Looks pretty good, what nissan did the power steering come out of?
Amilla
Offline RHodge
  • 523
« Reply #4 on: May 20, 2008, 06:43:02 PM »
Amilla
88 hardbody 2wd, the tie rod is a 94 nissan pathfinder inner, had to reem out the pitman arm a little
Offline RHodge
  • 523
Re: Nissan Power Steering Box
« Reply #5 on: June 09, 2008, 06:49:02 PM »
Just wanted to give a big thanks to Brent |removethispart|@ http://www.trailtough.com/default.htm for getting my drag link out to me so fast after being jerked around by a steel shop here in town ( CDA metal wanted 133.00 for 4' 1" .250 Dom tube what a AZZ !!! )
Ryan
I found a great place to get steering joints
http://www.woodwardsteering.com/Cat05/Cat05%20PDF%2049-55%20may%2007%20update.pdf
« Reply #6 on: July 02, 2008, 06:42:31 PM »
Ryan, I can't thank you enough for that link to Woodward, they have the
parts I have been looking for, for years now. I can finally build the slip shafts
for the IFS sidekick half shafts, and the parts are off the shelf, just have them
send an order.
For all those who are going ??? this is a way to 1 lengthen the a-arms and
2 eliminate the CV cup that is on the inner side of the CV shafts. Now you
might be saying so.... ??? the CV cups only have about a 25* angle capacity
before they are strained, where a standard CV such as the outer can go to
about 40* instead, so this gives the front IFS the ability to travel an additional
ohh lets say 2" over stock parts, in theory making a long travel sidekick. Getting
a little more interesting? well for some anyway, and those that arent interested
that's fine too, but I like a healthy RTI and BTW the turbo sidekick scored a 958
at the High Desert Roundup last year, not too shabby for home growed stuff
 8)
Offline RHodge
  • 523
« Reply #7 on: July 02, 2008, 10:01:52 PM »
send an order.
 8)
glad I could help
