Nope. V6 has different belhousing. Someone might be able to make an adapter plate similar to the 1.3 to 1.6 plate...-Eric
Quote from: ebewley on May 22, 2008, 09:39:26 AMNope. V6 has different belhousing. Someone might be able to make an adapter plate similar to the 1.3 to 1.6 plate...-EricIs it the same gearbox? will the bellhousings swap?
So swapping in a V6, you could use the matching tranni and not need to modify too much?I don't mean mounts, I'm more or less wondering if the length is similar to place the t-case in the same spot.
Quote from: Uncivilized on May 23, 2008, 02:55:32 PMSo swapping in a V6, you could use the matching tranni and not need to modify too much?I don't mean mounts, I'm more or less wondering if the length is similar to place the t-case in the same spot.Yep, t-case mounts are in the same spot as with the 4 cylinder transmssions and t-cases.-Eric
Other than the obvious, what is the benefit from this swap over the 1.6 16v LSI. Is this swap really worth the trouble?
