Sidekick 2.0L Swap...
  • 22 Replies
  • 9215 Views
Re: Sidekick 2.0L Swap...
« Reply #15 on: May 22, 2008, 01:40:26 PM »
Nope. V6 has different belhousing. Someone might be able to make an adapter plate similar to the 1.3 to 1.6 plate...
Is it the same gearbox? will the bellhousings swap?
  • 6554
  • 64
« Reply #16 on: May 23, 2008, 09:15:01 AM »
Nope, not that I've seen. The similarity is at the end (back) of all of the transmissions.... and that's a good thing for you can use the larger more substantial V6 transmissions and mate them to your sidekick t-cases that you've spend moola on the gearsets for.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #17 on: May 23, 2008, 02:55:32 PM »
So swapping in a V6, you could use the matching tranni and not need to modify too much?
I don't mean mounts, I'm more or less wondering if the length is similar to place the t-case in the same spot.
  • 6554
  • 64
« Reply #18 on: May 23, 2008, 03:26:16 PM »
Yep, t-case mounts are in the same spot as with the 4 cylinder transmssions and t-cases.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #19 on: May 23, 2008, 04:21:35 PM »
Have you done this peticular swap yourself Eric? (the V6 I mean)
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
« Reply #20 on: May 23, 2008, 04:33:43 PM »
Other than the obvious, what is the benefit from this swap over the 1.6 16v LSI.  Is this swap really worth the trouble?
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
« Reply #21 on: May 24, 2008, 10:02:19 AM »
FYI:
aftermarket4x4.com carries the bushing you need to mate the 2.0L to the 1.6L transmission.
Depends on if more power is your thing... 99 HP & Torque vs 125 HP / 136 Torque.
« Reply #22 on: May 28, 2008, 12:09:53 PM »
Well, as mentioned, power increment is the obvious reason but most importantly, engine availability and exchangeability. J series engines are still being produced by Suzuki, as found in the new SX4's (J20) and the J18 (Esteem/Baleno) and J23 (Aerio/Liana) are completely swappable with the J20 and Trackick trannies (4 cyl). So this means that if my newly swapped J20 fails someday I can just buy a J23 off a 2007 Aerio or a J20 off a 2008 SX4 and have the benefit of an up-to-date motor on my "old" 98' Kick.
Doesn't that sound incredibly awesome!!!! Hehehe
