Rear Disc Brakes on Sidekick...
  • 24 Replies
  • 4057 Views
Offline aaron74
Re: Rear Disc Brakes on Sidekick...
« Reply #15 on: May 08, 2008, 10:00:20 AM »
hmm... maybe they are thinner at the wheel bolts and you don't need extra long wheel studs.  The front studs are usually longer than the rears but that doesn't always mean there is enough to get through the turned down drum, the disc, and, say, aluminum rims.  It kind of depends on the disc design.  If the Kick disc is a bigger diameter, you will have to turn the drums down less but if the Sami disc is offset more, it is easier to fab a caliper mount and clearance rims.
Did you use a Sami t-case or calipers with rear e-brake, Rhinoman?
I used to be indecisive but now, I'm not so sure.
« Reply #16 on: May 08, 2008, 11:40:14 AM »
I used Ford calipers with ebrake. The ebrake ratio wasn't very well matched to the Zuk handbrake mechanism so i had lots of travel. With the stock m/c I had loads of pedal travel too. Someday I'll have another go at it but I lost patience with it and went to LWB brakes front and back.
I used turned down drums for the adapters, there are two different designs of drums, one has large internal webs and isn't as suitable. Longer wheel studs are a must, the front studs are too short to work. Like you said the stud has to be long enough to take the adapter and the thickness of the wheel. It also has to have  a shoulder that is long enough for the discs to locate properly on.
The Zuk studs and drums are like cheese, once the original studs had been knocked out the splines were too loose to take a stud with the same size spline so we reamed out the hole and fitted a stud with a larger diameter spline. The studs were an imperial stud IIRC so the front and rear wheel nuts were different, that bugged me too, but at the time we couldn't locate a metric stud with a better fit.
Offline aaron74
« Reply #17 on: May 08, 2008, 12:03:03 PM »
Yep, I have tired out a few parts guys over the wheel stud hardware - they should just give me the book ;)
Sounds like the ford calipers are a scratch.
As far as the wheel studs go, another option is to put the front Kick studs into the disc only and drill another five holes to hold the turned drum to the disc.  Use your turned drums as drill guides for offset holes and then bolt them to the discs and use them as guides on your discs.  You will need spacers between the disc and the turned drum to clearance the stud heads but other than that, your 'cheesy' hardware and different sized lug problem should be solved.
Aaron
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #18 on: May 08, 2008, 04:09:40 PM »
There's gotta be some way to make use of some wood in this.
XL-7 front coils
1.5" rear coil spacers
« Reply #19 on: May 11, 2008, 10:00:52 AM »
Thanks for all that info guys!!! I'm still looking into the Swift GTi calipers. The guys over at www.twmswift.com aren't giving me any help so I'll go to my local Suzuki dealer and ask some. I'll post what ever info I get.
« Reply #20 on: May 11, 2008, 10:59:36 AM »
Guys, I'm sorry. Someone did help me over at teamswift.com forums but I just didn't noticed. So it's my bad. They said that the Swift GTi has ebrake built in the caliper. I will look further into this to get measurements on caliper mounts and disc brake clearance.
« Reply #21 on: May 11, 2008, 01:28:59 PM »
Swift GTI calipers have been used over here but they are generally considered as not powerful enough for a Track/Kick.
« Reply #22 on: May 12, 2008, 05:43:05 AM »
Oh, bummer!!! Well, off to another search!!!
Offline Element
  • 1902
  • LillyKicker
« Reply #23 on: May 12, 2008, 10:53:57 AM »
Q: For the 2dr guys running bigger tires, can you swap to the 4dr brakes for a little extra stopping power???
zUkTAH
U4WDA
« Reply #24 on: May 12, 2008, 11:32:43 AM »
Yeah thats what I run now.
