Stock Carburetor Secondary Issue
  • 979 Views
Offline bobearski
  • The Bearzuk
« on: April 26, 2008, 11:47:56 PM »
...having an issue with the stock carb secondary not opening, or should I say not getting fuel.  Does anyone have any info if they're something electronic that controls this, or which component controls this; switch, relay, sensor.  I've replaced the carb 2 with different remanufactered units, all three having the same issue.  I know there's  electrical solenoids and switches.... looking for somewhere to start.  The electronic parts are expensive, so is a carb diaonostic!
Thanks!
« Last Edit: April 26, 2008, 11:52:18 PM by bobearski »
Re: Stock Carburetor Secondary Issue
« Reply #1 on: April 27, 2008, 09:22:18 AM »
Are you sure that its not opening? It needs a reasonable load to get enough vacuum so you aren't likely to see it open while stationary.
Offline bobearski
  • The Bearzuk
« Reply #2 on: April 27, 2008, 12:51:52 PM »
...pretty sure its not opening.. you can't feel the power when driving, or hear any difference with the air cleaner off.  I've found a test from Autozone online that tests the idle and WOT "wide open throtle" microswitches.... guess I start there. ....will post results.
Link to test:
http://www.autozone.com/az/cds/en_us/0900823d/80/1e/01/08/0900823d801e0108/repairInfoPages.htm
