If you had to work on the transmission... what else would you do?
  • 27 Replies
  • 4035 Views
Offline Carnage
  • 2453
Re: If you had to work on the transmission... what else would you do?
« Reply #15 on: April 15, 2008, 09:38:17 PM »
Can some one buy fancy up-graded clutch disks for a Kick auto in the first place? ???
How about a torque converter and valve body for the same tranny?
i dont need top-of-the-line, just better
so suggest away
pics and info would be great too
but at the very least leave a link so i can read
(since im not that transmission savy)
ive heard something about a Centerforce Dual friction clutch kit
not really sure what that entails, so if anyone has info pls share
« Last Edit: April 16, 2008, 04:32:39 PM by Gen-Erix »
Offline mic
« Reply #16 on: April 16, 2008, 05:13:48 AM »
There maybe a shift kit available, it remaps your valve body a bit giving you firmer shifts. Try "B&M shift kits". ???
91 Tracker Calmini 3+3 31x10.5 swamper ssr
88 samuri 3" body 2"susp. 31x12.5 boggers sold
03 super duty daily work truck $$$$gas
Offline Carnage
  • 2453
« Reply #17 on: April 18, 2008, 09:27:39 AM »
how are the clutches on ebay?
theres an EXEDY one for $130
a STAGE 2 for $165
and a STAGE 3 for $215
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #18 on: April 19, 2008, 09:07:24 AM »
a STAGE 2 for $165
These are for standard transmissions. I have a transmission parts catalog at my shop - will check to see if any valve body kits are availible later and post what I find.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Carnage
  • 2453
« Reply #19 on: April 19, 2008, 03:31:14 PM »
a STAGE 2 for $165
Derek
youre right
what would i need for an auto trans from a 95 4dr kick
Offline derekj
  • 784
« Reply #20 on: April 19, 2008, 05:15:27 PM »
My catalog does not show any valve body kits for that transmission. Check with your parts suppliers to see what they have.
Derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
Offline RHodge
  • 523
« Reply #21 on: April 19, 2008, 09:00:15 PM »
If it works and is not slipping I wouldn't mess with it, But you should at lease put new front pump seal and a rear output shaft seal in it. If it needs work I don't think your going to find performane parts for it, but you should be able to get a good good build kit for it though
Later Ryan
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #22 on: April 21, 2008, 06:43:20 AM »
ya man..id just put whatever new parts in there that ya need....like the clutches and stuff it all back together...considering that you have X ammt. of miles on there already and they lasted this long being oem...but if it was me id put new ft. pump seal and output seal in the trans...im not too familiar with the 4 sp. but i know that my 3 spd. has a selector shaft seal where the shifter goes thru the case...REPLACE THIS!!! i just had to replace my yesterday..and you also may wanna put a new rear main into her as well while ya have it seperated just for good measures....
ENJOY THAT BEER 2!!!! that should always be a steady consumption in hot climates as in hawaii!!! dehydration is never good...thats why they make budlight...more water to re hydrate ya...haterade is some bull ish!!!
Offline Carnage
  • 2453
« Reply #23 on: April 21, 2008, 01:31:14 PM »
this is what i have so far
Transmission Filter
Front Pump Seal
Output Seal
Selector Shaft Seal
Rear Main Seal
is there anything im missing?
(the transmission has over 100k)
X32CarDomainPage.........................RyouBakua|removethispart|@Hotmail.com.........................BurpleCarDomainPage
Help me Heal!!! No spam/pop-ups.  Just one click!!!   Or be a TechWarrior!!!  Its cool!!!
I've actually won $75 online but I play everyday for a chance at the big $1,000,000.00!
Almost no spam and its FREE!  Click here to sign up for your 10 chances a day!
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #24 on: April 26, 2008, 12:32:08 PM »
did ya get her all back together???
Offline Carnage
  • 2453
« Reply #25 on: April 26, 2008, 04:19:36 PM »
not yet
Transmission Filter
Front Pump Seal
Output Seal
Selector Shaft Seal
Rear Main Seal
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #26 on: April 27, 2008, 10:04:09 AM »
yessir...if that was me thats about all id do to it...n just a word of advice....look for the rubber trans pan gskt...some parts stores have the cork ones with the filter kit, but after i re-did my stoopid cork gasket about 3 times tryin 2 seal it up, my pops told me to get a rubber gskt....that was about a year ago....not a drip outta the pan!! but just remember...do everything that you possibly can with that whole cluster F...outta the way its so much easier than struggling aginst everything
Offline Carnage
  • 2453
« Reply #27 on: April 27, 2008, 12:42:30 PM »
roger that
