9.5 X 27 or 10.5 X 27 ??
  • 1304 Views
« on: April 09, 2008, 02:36:30 PM »
Maybe some one here knows..
Vehicle is 90 Tracker 2 door.  Old man emu springs and shocks, they give around 1.5 to 2 inches lift.
8 inch Centerline wheels.  15 inch wheel by the way..
Can I get away without the 10.5s rubbing??   Anyone running a 27 X 9.5 or 10.5 on 8 inch rims??
Thanks, Dennis
Offline Uncivilized
  • 1469
    • Car Domain
Re: 9.5 X 27 or 10.5 X 27 ??
« Reply #1 on: April 09, 2008, 05:29:56 PM »
What are you worried about them rubbing? I don't think you have anything to worry about, even though there is a lot of width, you have a smaller diameter.
« Reply #2 on: April 09, 2008, 07:29:10 PM »
Can I get 29s on it and if so how wide??
Offline rascott
  • 669
  • 15
« Reply #3 on: April 09, 2008, 08:56:40 PM »
dennis from oregon
i don't know if this will help, but i was trying to run 31x10.5's on 8" rims w/2" suspension+1 1/8 body lifts and rubbed inside rear up front(minor hammering).
i went back to 7" rims and have better clearance.
mabe 29's will fit.
« Reply #4 on: April 10, 2008, 01:10:06 PM »
Its my GFs tracker, I dont want to get too crazy with it.  It sees plenty of pavement too.  She dosnt want me going any higher in lift, yet wants as aggressive a tire as possible..
So Im trying to figure out what I can get under there without alot of work.  Hopefully no work.  Retubbing inner wells is a bitch...
The 27s are right at the same diameter as the 205 75 R15s, the 29s are of course a bit taller.  She wants wide, I dont want to do a bunch of work..
Can anyone tell me their experience with 29s on 8 inch rims??  Or 27s??
Offline tracker8v4x4
  • 128
    • cardomain
« Reply #5 on: April 11, 2008, 04:32:56 PM »
im running 30x9.5x15 on tracker rims and without a lift they dont rub unless u really have iit flexing idk if tis helps at all
