Almost done project
  • 14 Replies
  • 2258 Views
Offline Shizamaaur
  • 81
Almost done project
« on: April 07, 2008, 06:03:42 PM »
Well everyone I finally got all my parts in for my 1991 1.6L 8v Throttlebody EFI swap to my 87 sammy, got everything in, and well when i start it, it starts for about 1 second then dies. but if someone sprays starting fluid itll stay running... now i looked in the manual and i looked at my injector power plug? and i pulled it and it still does the same freaking thing! no matter if it's plugged in or not! please you guys tell me its an easy fix as i am ready for cruising with the top off. PS the harness was done by trailtough. i also bought the fuel pump from trail tough and its running right ???
Offline baltz526
  • HUNTING IS WHY
Re: Almost done project
« Reply #1 on: April 07, 2008, 07:40:36 PM »
i would make sure all plugs are getting contact, fuel celinoid
LAPINE OREGON
Offline Shizamaaur
  • 81
« Reply #2 on: April 08, 2008, 04:33:05 AM »
Ive already checked. Also what should the gap be on the plugs? any other ideas????????
Offline Shizamaaur
  • 81
« Reply #3 on: April 08, 2008, 03:11:41 PM »
?? help please
Offline rascott
  • 669
  • 15
« Reply #4 on: April 08, 2008, 04:09:21 PM »
i'm sure this won't be much help, but it doesn't sound like an ignition problem if it'll pop with starting fluid.
must be something w/injectors or fuel pressure?
Offline Shizamaaur
  • 81
« Reply #5 on: April 08, 2008, 05:22:55 PM »
I just don't know what it is!  ??? ??? damn it.. messed around with it today but im back where i started... Like i said it'll start for about 1 second then die, every time unless i spray starting fluid in, itll stay running. please anyone help me lol im sorry i sound desperate but i want to get it running
  • 6558
  • 64
« Reply #6 on: April 08, 2008, 06:06:52 PM »
Jump a hot wire straight from the battery to your fuel pump and then try running the vehicle.
Offline Shizamaaur
  • 81
« Reply #7 on: April 08, 2008, 06:08:43 PM »
I thought that myself but the only thing i dont understand is, i can hear it running even when the motor is turning over, it only stops after i turn the key off after the motor runs for 1 second
Offline Shizamaaur
  • 81
« Reply #8 on: April 08, 2008, 06:17:59 PM »
Also i used a meter to test the voltage coming out of the plug to my injector power, it was pushing 10v, what color is the plug supposed to be? and dont forget tt did my harness, thanks!
« Reply #9 on: April 09, 2008, 04:59:36 AM »
Was everything running OK in the Tracker before the conversion?
« Reply #10 on: April 09, 2008, 04:03:53 PM »
The cold start enricment is working, so you have fuel.  It starts, you have ignition.  My guess is the injectors arent working...
I would call Trail Tough, they are a good outfit, they can probably help you isolate the right circuit in no time at all.
They work on these all the time...
Offline Shizamaaur
  • 81
« Reply #11 on: April 09, 2008, 05:34:18 PM »
Well folks, found the problem and it's a weird one. I called Brent at TT and he told me it was the Noise Suppressor. So I went to the junk yard and the guy told me to just go ahead and take it... for free. That made me pretty happy and so i rushed home from work to install it to try it.... anddddd..... nope same thing!  :'( tired and discouraged that it would never run, I was about to put it away when I looked at the 3 prong connector to the N.S. and I noticed it had 2 browns and one black. Out of no where i just thought F it and i put a paper clip in to connect the two browns. Not thinking it would work I fired her up one last time... andddd BAM it stays running!!!!  ;D ;D ;D ;D :laugh: :laugh: Kinda a weird fix but it's running good and my Sami has a wholeeeeeeeeee new feeling of power (all new petroworks clutch, new flywheel, new pretty much anything that needed replaced. THANKS EVERYONE FOR YOUR HELP!!!! ILL HAVE PICS UP SOON!!!! :D :D :D :D :D
Offline baltz526
  • HUNTING IS WHY
« Reply #12 on: April 09, 2008, 06:46:34 PM »
 ;D like i said, check your plugs :P
LAPINE OREGON
Offline Shizamaaur
  • 81
« Reply #13 on: April 09, 2008, 07:06:11 PM »
A weird fix eh? lol I hope it'll stay running right!
Offline Fasta76
  • 133
« Reply #14 on: April 11, 2008, 04:57:03 PM »
Were you happy with the harness from trail tough? Did you buy the whole kit from them? Im thinking of doing the same swap! Please let me know.
Tom
