Fighting a code 15 (Coolant Temp High)
  • 1105 Views
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« on: April 05, 2008, 02:43:39 AM »
 But the truck runs noraml temp!  New Radiator / New Thermostat.
My problem memics the one in this thread:
http://www.zukiworld.com/forum/index.php?topic=9498.0
But no solution was given.   I'm hoping to check the sensors tomorrow.  I know one looked white and fuzzy when I changed the thremostat.
This is on a 1995 2dr 1.6L 16v Auto 4wd.
This truck has (3) temp sensors.  I have installed a new temp sensor for the dash gauge (front of water outlet housing) as a precaution.
Reset codes and CEl code 15 will return in about 30 miles.
Re: Fighting a code 15 (Coolant Temp High)
« Reply #1 on: April 05, 2008, 02:19:18 PM »
Sounds like an open circuit sensor.
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #2 on: April 06, 2008, 01:28:22 AM »
2.5K ohms at 65-70 deg. F
The same temp sensor in my Rock Buggy (1994 1.6L 16v) gave a similar reading so I believe this is a correct value.
I'll check the circuit next week when I get the spare sensors.
Truck got a new owner today even with the CEL and code 15.
I've signed up to replace the temp sensor and look into it further.
