Lifted sidekick tracker rear shocks?
  • 24 Replies
  • 15351 Views
Offline v-stone
  • 625
« on: April 03, 2008, 11:52:58 AM »
I've seen several differant types of shocks people have used for a 2" lift before, just can't find where now. So I'm starting a new post for it!
Please list the shocks (what they're off of) you have used here. Thanks for the help
SAS Tracker! No looking back now.
Offline MUD CHILD
  • 355
  • 9
Re: Lifted sidekick tracker rear shocks?
« Reply #1 on: April 03, 2008, 12:39:11 PM »
I think if you use the search feature you will find all the info you need
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline bzzr2
  • 1011
« Reply #2 on: April 03, 2008, 01:00:25 PM »
i use 95 mustang shocks, they are longer than the crown vics a lot of people use.
09 taco reg cab short box 4x4
Offline donovanperro
  • 27
« Reply #3 on: April 03, 2008, 03:48:35 PM »
i also heard of 91 crown vics will work to
Offline Dale.E
  • 26
« Reply #4 on: April 03, 2008, 04:48:03 PM »
I got a pair of Monroes from Lordco, but the f'ed up on the numbers and I did not know it till I went wheelin.  I told them I needed a set 2" longer than stock when fully extended.
They supplied me with a set 5.25" longer.  now my springs almost fall out when fully extended.
not going back there, I did my own math this time and ordered a set of ProComp #120510 shocks.
They are almost the same price and even come with rubber boots.
I think now on hind sight I should not have played the cross reference game, the ProComp shocks actually list that number as for a 2" lift.
Offline rascott
  • 669
  • 15
« Reply #5 on: April 04, 2008, 08:38:55 AM »
i am using mustang rear shocks also.
a good auto parts store will let you look thru the shock spec. book. it lists lengths and mount types.
i figured the 'stang was lighter than the vic? bolted right in. feels good.
Offline bzzr2
  • 1011
« Reply #6 on: April 04, 2008, 09:35:06 AM »
my 'rustang' shocks are also 1.5-2in longer than the crown vics.
Offline v-stone
  • 625
« Reply #7 on: April 04, 2008, 08:43:08 PM »
OK. I've heard of 91 crown vics, 95 mustangs and kinda remember F150. I looked at the vics and the stangs tonight. It looked like the mustang would work better, same diameter bolt for the lower mount.
Installing tomorrow ;D
« Reply #8 on: April 04, 2008, 09:45:03 PM »
I've got the vics on mine and I did measure and they were truely 2" longer than the stock ones.  I am curious on the mustang shocks.  Does it matter what engine the mustang had or do all 95 mustangs have the same shocks?
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #9 on: April 05, 2008, 09:01:16 AM »
all the mustangs do have the same shox...i have a the monroe part # on one of my old posts....if ya cant find it i can get it when i get home...i like the monroes because they are prettycheaply priced and lifetime warranty....so who cares about the boots??
Offline aaron74
« Reply #10 on: April 05, 2008, 09:40:29 AM »
I disagree on the mustang shocks being all the same!
I originally bought from Lordco, but on a whim checked the next door neighbour parts place and they crossed the shocks to two different Gabriel shocks: one was the same price because it was for a performance handling package and the other was $30 less because it was for the regular handling package.  I, of course, saved myself $30 and some extra valving that I don't want anyway.
The number I had was from a posting on this site.  Oh, and I measured them all ... they were all pretty much the same dimensions on the counter (But I have long since chucked the bit of paper I wrote it all down on.)
Cheers,
Aaron
I used to be indecisive but now, I'm not so sure.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #11 on: April 05, 2008, 04:00:17 PM »
F150 shocks work, and they're 3" longer than stock. Problem is, the tube is thicker so you need to modify or change the lower mount so it doesn't hit on up travel. You can buy shock mounts from Sky Manufacturing, they're not listed in their website, but they have them. Or you can make a set with the proper bolt, some metal and a welder.
Offline Jookycola
  • 372
« Reply #12 on: April 05, 2008, 09:27:37 PM »
So if you get the longer shocks for the rear...what do you guys use for longer Struts up front?
  [/url]
Offline Element
  • 1902
  • LillyKicker
« Reply #13 on: April 05, 2008, 09:33:21 PM »
People will do any of the following:
Old Man Emu struts
Strut mount flip
Strut spacer
Longer struts included in various lift kits(calmini,ect)
Thread on strut extentions
Sometimes combo's of these...
I'm sure there are a few I missed...
zUkTAH
U4WDA
Offline Jookycola
  • 372
« Reply #14 on: April 07, 2008, 07:37:17 AM »
A strut mount flip is snough of a lift upgrade to match the longer Crown vic shocks?  Or should you do a combo of flip and spacer.
  [/url]
