1990 8v tracker idle problem
  • 993 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« on: March 19, 2008, 10:10:11 AM »
ok i finally got my tracker running good now the only problem is that when it warms up it idles at 1500 rpms.  Does anyone know how i can change this.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: 1990 8v tracker idle problem
« Reply #1 on: March 19, 2008, 03:27:59 PM »
set your timing at 10 degrees BTDC and work your way to 8 or 6 see where it idles right and has no hesitation, if that's not it make sure the throttle cable isn't  too tight it shouldn't have play but shouldn't be tight either, then you can try your tps it will change your idle significantly
Offline Armour
  • 360
« Reply #2 on: March 19, 2008, 08:09:21 PM »
Also check for vacumm leaks. A vacuum leak could cause this!
