Pre-96 t-case in a 97 Sidekick?
  • 1371 Views
Offline olija
  • 770
    • Check out my cardomain
« on: March 18, 2008, 09:28:36 PM »
I've recieved my TrailTough gears in the mail. Instead of paying big bucks to have someone install them in my current t-case, I was thinking it would be much cheaper to just buy a used Sidekick transfer case, put the 4.24's in there, and then swap the transfer cases in one shot. That way I don't have to worry about getting it done by the end of a weekend. In theory this will work, the only thing I'm not 100% sure on is the output spline count...I read somewhere they are different on 1996-1998 models...is this true and can I somehow work around this?
Re: Pre-96 t-case in a 97 Sidekick?
« Reply #1 on: March 18, 2008, 09:38:48 PM »
Call Brent and ask him!
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #2 on: March 18, 2008, 10:04:03 PM »
Just swap the yoke (make sure you get it with the t-case) on the tailshaft that goes in to the rear of the t-case to suit. It's an opportunity to put a new universal joint in there at the same time. I have done this before and am about to do it again when I swap t-cases in the next couple of weeks.
« Reply #3 on: March 18, 2008, 10:10:47 PM »
............the only thing I'm not 100% sure on is the output spline count...I read somewhere they are different on 1996-1998 models...is this true and can I somehow work around this?
Yes, they are different.
Swapping yokes is a work-around.
Swapping output shafts is another work-around (although probably not as feasible).
