8v Tracker clutch pedal
  • 10 Replies
  • 1800 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« on: March 17, 2008, 07:40:00 AM »
I have a 1990 geo tracker ant the spline shaft broke on the pedal.  Does anyone have instructions on how to drop that pedal assembly and also does someone have a pedal assembly for sale.  i need one pdq.  this is my vehicle i drive back and forth to work.   thanks in advanced
Offline Chief
  • 678
  • Whaddya lookin at??
Re: 8v Tracker clutch pedal
« Reply #1 on: March 17, 2008, 12:38:25 PM »
you actually broke that shaft all the pedals ride on?! Wow. I'm not much help, but I thought I was up sh*t creek when the clutch cable popped off the arm!
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
« Reply #2 on: March 17, 2008, 12:55:50 PM »
http://www.suzukiinfo.com/ if you go there, you can download the hayne manual that might be helpful...
BTW if you broke the pedal shaft, you should check the clutch cable it might be seize..
Offline kubik1981
  • 232
« Reply #3 on: March 17, 2008, 01:06:42 PM »
the cable is fine i can actully pull it with my hand.  thanx for the hlelp
Offline tracker8v4x4
  • 128
    • cardomain
« Reply #4 on: March 18, 2008, 12:42:01 AM »
if u can move the cable whats the problem then jlust hook it up to the e brake handle :laugh: i belive to remove the assy u have to pull the dash out
Offline MaD.72
  • 183
« Reply #5 on: March 18, 2008, 07:58:33 AM »
BTW don't remove all the assembly, just remove the pedal..
Offline kubik1981
  • 232
« Reply #6 on: March 18, 2008, 07:25:05 PM »
i got it all back together today and running,  But now the idle goes from 800 to 1500 and back down to 800.  I unhooked the computer to get the pedal out.  But it is running Alot better then what it was doing. I had no power before.  the blue connecter on the computer was loose so fixed that
Offline MaD.72
  • 183
« Reply #7 on: March 18, 2008, 07:36:19 PM »
Did you unplug the battery??
Offline kubik1981
  • 232
« Reply #8 on: March 18, 2008, 07:55:05 PM »
yes i did
  • 128
    • cardomain
« Reply #9 on: March 18, 2008, 08:33:03 PM »
i would drive it for awhile the comp may just be learining from being unpluged  ???
Offline kubik1981
  • 232
« Reply #10 on: March 18, 2008, 08:39:19 PM »
well i drove it home and after it is warmed up it idles fine then when u shut it off and start it it does it again.  also like i said it is running a lot better then what it did before i did that with the computer
