Need major help with carb quick
  • 1155 Views
« on: March 16, 2008, 02:21:30 PM »
Running a stock 1.3 in a 1988 Samurai. Everything was fine until earlier today. I was driving at 45mph and stopped at a stop light the carb decided not to idle down and then went up to about 6000 rpm. I shut the key off and tried to start it again and it went up to about 6000 rpm again before I could shut the key off. Does anybody have any ideas? I really need this fixed so I can get to work. Thanks in advance. Also, this was running perfect before this happened.
« Last Edit: March 16, 2008, 02:25:20 PM by axelnut1 »
Offline Gary_Hill
  • 288
Re: Need major help with carb quick
« Reply #1 on: March 16, 2008, 02:44:10 PM »
You have a bad throttle cable...probable at the hole where it goes thru the firewall. Should be easy to see if that is the problem.
Offline ROSS
  • 1412
« Reply #2 on: March 16, 2008, 05:54:21 PM »
gary is wise OLD man  .  sounds like throttle cable
Offline RHodge
  • 523
« Reply #3 on: March 16, 2008, 07:58:42 PM »
I had a stock carb do that, was out wheeling climbed a hill when I got to the top RED LINE I messed around with it for awhile but never figured it out just put a weber on it
but I third the cable, good place to start
Offline Gary_Hill
  • 288
« Reply #4 on: March 16, 2008, 11:49:55 PM »
The cable will be frayed on the inside of the firewall if I am correct...let us know what you find....Gary
