test run of the 87 samurai
baltz526
34
HUNTING IS WHY
March 10, 2008, 08:55:15 AM »
WELL
the first bad road i took it on, i stuck it. sugar snow over ice. sitting on the ice i had one wheel turning (right rear) transfere in 4 low and hubs locked. handiman jack and chains on the rear and i was free. now that i know i need better differentials, please tell me what to buy. dependable, i'm running 235/75/15 and do not plan on anything larger, should i trade out gears at the same time, what should i buy?
Last Edit: March 11, 2008, 07:55:33 PM by baltz526
LAPINE OREGON
Amilla
1076
Toyota running gear was made for a samurai!
Re: test run of the 88 samurai
March 10, 2008, 10:21:39 AM »
You could just get a lock rite for the rear, possibly the front it you were up for it.
Im not sure what tire you are running, but air that baby down, seems to do pretty good in the snow.
Amilla
baltz526
34
HUNTING IS WHY
March 10, 2008, 08:57:50 PM »
i'm running a new set of winter ice tires at 26psi. i need better front pull for sure. is the lock rite the best choice for front and rear.
LAPINE OREGON
Amilla
1076
Reply #3 on:
March 11, 2008, 10:03:08 AM »
ARB is the all time best way to go...if you willing to drop a couple grand.
If not the Lockrite and Ez lockers are pretty much the only other ones around. There are full spools and mini spools available, i would only run that on a trail rig.
There is also a limited slip that you can get from calmini...If i were going to spend $450 on a locker i would just go the whole 9 yards and go ARB.
Hope that helps out.
Amilla
baltz526
34
HUNTING IS WHY
Re: test run of the 87 samurai
Reply #4 on:
March 12, 2008, 08:26:55 PM »
lockrite is $199 part# LR1510 think i'll get one. today i jacked the front wheels off ground locked the axles in put it in 4 low and spun the wheels, they spun opposite each other, but the drive shaft did not turn
LAPINE OREGON
Amilla
1076
Reply #5 on:
March 13, 2008, 09:53:29 AM »
A locker will fix that little problem up real nice!
Good luck
Amilla
