Here is an update on what I did. Tracker was on 4 metal car ramps, plenty of room under the vehicle for Bullet Proof Tansfercase vs. Crazed Mechanic wrestling match.
There was no way in hell I was going to get to the top two bolts, even with the rear transfercase crossmember removed. My gorillia
![Angry >:(](https://www.zukiworld.com/forum/Smileys/aaron/angry.gif)
hands just did not fit, and I have the scabs to prove it.
If you have a 3 inch body lift I imagine it could be done, but I have no body lift.
I started to remove the transmission, when I discovered the possiblity of stripped threads in the transmission for the 2 bolts that secure some kind of bracket to the transmission (passenger side).
So I found another solution, I got out the cutting wheel and created two access panels on both sides of the tunnel hull. Worked like a charm! I now have to create access plates out of them, that will be RTVed in place. When I get the mod done I'll post some pics. End result, the transfercase can now be removed from the transmission while the transmission stays mounted to the engine.
Floor jack was only used to support the transfercase when connected to transmission. Otherwise, I just wrestled the transfer case off and on the transmission.
I do have a couple of questions:
Question 1:
The wire harness that plugs into the top of the transfer case, and runs along the top of the transfercase and transmission, what does the other end plug into (2 pulgs)? When I removed the old transfercase, these plugs were not plugged into anything, and I can not seem to find the plugs that they would plug into.
Question 2:
What year did the transfercase spline count on the rear output shaft change? I have a 93, bought a rear drive shaft out of 96 (I believe?) and the splines on the 96 were larger diameter and fewer spline count. My 93 driveshaft where smaller in diameter, and higher spline count.
EDIT< I just read that the newer Transfercase output shafts are 16 spline and the older are 26 spline, still do not know what years they made the switch?
>EDITI could have fixed the problem by swapping the slip yokes, but my slip yoke is all boogered up from the rear driveshaft falling off at 60+ mph.
Question 3:
Is there anything I should salvage out of the bad transfercase for spares? The rear housing is cracked. I'm thinking the bolts, since it's hard to find automotive grade bolts.
Ryan
