Two inch lift.
  • 975 Views
BIG DOG
Two inch lift.
« on: February 04, 2008, 08:18:35 PM »
I'm going to do the 2" body lift I'm wondering if I should use 2"X 3" tubing to do this?If you cut the tubing so that you had a 3" square it would give a bigger pad for the body puck to fit on.Or will 2"X 2" big enough for the pad to sit on?Also a 2" tubing will actually give a 2.5" lift won't it? As part of the body puck fits down inside the frame bracket about 1/2" or am I wrong about this?And will 1/8" tubing be ok or should it be 3/16".
It's a 95 16V 5spd 2door.
Thanks!
big_kountry21
Re: Two inch lift.
« Reply #1 on: February 04, 2008, 08:31:10 PM »
hey i've thought about doing it that way .....i was going to use 2"x3". if that helps
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Two inch lift.
« Reply #2 on: February 04, 2008, 09:32:13 PM »
2x3" would work better to disperse the load on the rubber thingy.
1993 4-door Sidekick
4.24:1 t-case
MaD.72
Re: Two inch lift.
« Reply #3 on: February 05, 2008, 06:50:39 AM »
Check this there alot of information..http://www.zukiworld.com/forum/index.php?topic=20074.0
