92 rear axle into 97?
  • 1002 Views
Offline olija
  • 770
    • Check out my cardomain
« on: January 30, 2008, 08:06:43 PM »
I'm quite certain already that this will work, just need some confirmation that a rear axle from a 1992 Sidekick 2 door with 5.12's will work in a 1997 Sidekick 4 door with 5.12's. Both don't have ABS so that's not an issue.
Re: 92 rear axle into 97?
« Reply #1 on: January 30, 2008, 09:45:48 PM »
It should work as long as both are three link, I think they went four link in 98 or so, the axles will be diffrent but I think that the earlyer axles are stonger anyway even with the four bolts holding the drum on instead of the large flange, I'm running 94 axles in my x-90 it's a 96, has the same brakes to.
