knocking
  • 1634 Views
halfman halfamazing
knocking
« on: January 21, 2008, 01:07:36 AM »
i was playing in the sand with my zuki last weekend when all of a sudden i couldn't shift gears any more, it was like my clutch wasn't fully disengaging and letting me shift so i ended up driving about 3 miles in the sand in 1st gear steady at about 4-5 grand the whole way right before i got out of the sand my motor started knocking pritty hard (sounds like it's comming from under the valve cover).  i drove it home listening to revs to shift and there it has sat.  i pulled the valve cover and everything seems tight (nothing looks out of order), also i pulled my spark plugs and they all look fine as well, i don't know what to do. What could it be?  it knocks at about 2 grand stops at around 2.3 then starts up again at about 2.9-3.3 grand, it fuggin sucks.  and as for my clutch, the clutch it's self is new, a few months old, as well as the clutch cable, but these have already been punished so there is no reason for them to start acting up now unless my clutch is shot which would suck, but it's not slipping at all it just wont disengage. i don't know what to do any one got any suggestions? by the way i got a 94, 8v, 2 door sidekick.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: knocking
« Reply #1 on: January 21, 2008, 03:37:26 AM »
Not sure why you couldn't shift but you might check to see if you broke a u-joint. Does it knock at idle? I can't afford to go  in the sand or mudding myself.
-Adam ;D
halfman halfamazing
Re: knocking
« Reply #2 on: January 21, 2008, 10:20:56 PM »
yea, it does knock at idle, dammit!
mypocketsrfull
Re: knocking
« Reply #3 on: January 22, 2008, 09:04:30 AM »
well, as far as shifting is concerned, my samurai has a boot type thing on the cable that sometimes doesnt allow me to shift,  all i do is reach in and move it a bit and then i shift fine, maybe not the solution for you, but at least something to try
kubik1981
Re: knocking
« Reply #4 on: January 22, 2008, 06:46:09 PM »
i have a 1990 8v and i had a knocking sound that sound like it was coming from the valve cover.  Come to find out i spun a rod bearing.  have it checked out asap before it does irreplaceable damage.  Mine i cought in time that the machinest was able to save mine.
halfman halfamazing
Re: knocking
« Reply #5 on: January 24, 2008, 09:58:48 PM »
i i thought it had something to do with my valve rods, i think it's gonna be big bucks to fix though and might not be worth it, i got 170, 000 miles on it already so i don no what im gonna do?
Offline SidekickMN
  • 58
  • Waiting on  Money  for  Body Lift
Re: knocking
« Reply #6 on: January 25, 2008, 06:02:53 PM »
My 1.6 8v was nocking like that when i tore it apart i noticed i had bent my crank shaft.
1994 Sidekick, hard top, soft top, custom bikini top
30x9.5x15 mud tires
RRO 2.5"
Herculiner interior
kubik1981
Re: knocking
« Reply #7 on: January 25, 2008, 06:08:33 PM »
my motor had 190k on it, the guy who did my motor said it looked almost brand new inside
