axle strength??
  • 1465 Views
lockeddiff
axle strength??
« on: January 16, 2008, 05:54:41 PM »
how strong are the stock axles i know they can at least handle ##s but can they hold up with some 35s?
Re: axle strength??
« Reply #1 on: January 16, 2008, 05:58:44 PM »
It's all in how u drive, if you snap the clutch you could snap an axle too.
The only axle I have broken is a 22 spline front, and I was being stupid
got to bouncing under boost and pop she went
Re: axle strength??
« Reply #2 on: January 17, 2008, 10:30:53 AM »
Sidekick or Sami  ??? With 33's I regularly broke stock front anf rear axles. But then again I was following trucks MUCH larger than mine and pounding her hard.
Re: axle strength??
« Reply #3 on: January 17, 2008, 01:32:57 PM »
How long is a piece of string?
Re: axle strength??
« Reply #4 on: January 17, 2008, 02:21:54 PM »
about yea big.
lockeddiff
Re: axle strength??
« Reply #5 on: January 17, 2008, 02:28:25 PM »
i ran 33" swampers and had no problem
but i want to go to 35s
if you ran them with the upgraded calmini axels would they hold up to 35s
and its and 86 tintop sammi
its all regeared with the 6:1 calmini crawl gear
dual force clutch
heavy duty t-case mount
dual high steer system
5" lift
